Deck Removal GT235
/ Deck Removal GT235 #1
Oil Well South
JD GT235
I have a 38" deck on my GT235.
I do not have a manual.
How do I remove?
Thanks.
/ Deck Removal GT235 #2
:welcome:
Looks like you have the long rod on top to release the drive belt tension. Remove the belt from the drive. Then remove the pins on the lift bars, and drop the front bail (draft). Should slide right out then.
Thank you sir. I pulled that steel rod and it relived belt pressure. But I couldn't see anything that would drop the deck.
/ Deck Removal GT235 #4
You should be able to see the two pins with clips on each side just ahead of the rear wheels, that connect the lift arms activated by the manual lift handle. Remove those two pins on each side and the rear of the deck should be free. Then remove the front draft (I call it a bale/bail). Then there is likely a rod that has a very tricky clip on a rod to remove.
Here are some schematics of the parts.
First pic
Part 24 is the lift arm for the rear of the deck. Part 39 is the pivot that latches the front draft that holds the front of the mower deck. These parts are critical to the proper "leveling" of the deck and have adjusting threads on them. If the deck is in adjustment, no need to unthread anything. Just release the front draft.
Second pic.
Shows assembly no. 47 that has a clip to remove. This is the tricky one, as the clip is hard to reach and keeping the washer on when re-attaching is an interesting feat.
Third pic.
Shows the J-pins (part 23) on each side of the rear of the deck to pull out (spring loaded) and rear of the deck should drop off the lift arms.
/ Deck Removal GT235 #5
Deere is good about posting their manuals on their website. I suggest you check there for the removal/installation procedure.
/ Deck Removal GT235 #6
It will help to push the deck lift lever fully forward, and
lock it there (with the push button ). that will take any
spring tension off the lift so the deck should be resting
on the ground. remember to lift that back up before you try
to slide the deck out the side of the tractor.
I was busy this morning, but I am going to try to remove now. Will post back with results.
Thanks guys. Following your instructions, and the manual, made the removal pretty simple. I greased the zerks, and cleaned beneath the deck.
My new issue is going to be with the belt that connects the engine with the transmission. As you can see, the is a pretty wide cut into the belt material, appx 3/8".
How difficult is it to change this drive belt?
What would cause a cut into the material?
Thanks again!
/ Deck Removal GT235 #9
...........My new issue is going to be with the belt that connects the engine with the transmission. As you can see, the is a pretty wide cut into the belt material, appx 3/8".
Thanks again!
No idea but probably a good idea to have the spare one on hand if (when) it breaks through. The manual should give you belt changing procedure.
/ Deck Removal GT235 #10
need to know how the connecting bar hooks to the front of a john deere gt 235 tracter that holds the mower deck on need a dirgram its a 48 inch deck an sereail numberis 010001 an need to knowwhat year it is
2015 Isuzu NPR HD Septic Pump Truck (A62613)
2015 Isuzu NPR HD...
Informational Lot - Shipping (A63689)
Informational Lot...
2015 VANTAGE TRAILER 3 POD PNEUMATIC TRAILER (A63569)
2015 VANTAGE...
2022 EZ-GO ELITE...
2003 International 4300 Bucket Truck (A62613)
2003 International...
New/Unused Wolverine Quick Attach Auger (A65583)
New/Unused...
