Deck Leveling?
/ Deck Leveling? #1
gager2002
I just got this 455 lawn tractor and the deck os leaning to one side and down in front. How can I level this out? Not to mention the deck only comes up 1"-2" with the level. Total travel up and down is 1"-2".
/ Deck Leveling? #2
Manual procedure followed?
1. see that all brackets and lift points are locked in (J-hooks can slip out sometimes). check that mower blades are not bent. Raise the four mower deck wheels to high position
2. adjust air to right pressure in all tires.
3. Set mower height adjuster to 2½"
4. 'level' on a flat surface, and set right to left 'level' first,
measuring at the tips. Make them both the same height
from the level surface within 1/8"
5. measure front to back on the right hand blade under the tip when it is full forward, and the same tip when it is full back. Adjust the front 'bail' so that there is 1/8" to 1/4" lower in the forward than in the back measurements.
6. reset the mower deck wheels so they are about 1/4" above the level surface.
/ Deck Leveling?
I will try all this tonight when I get home
2013 INTERNATIONAL DURASTAR 4300 M7 SWEEPER TRUCK (A63276)
2013 INTERNATIONAL...
2012 Ford F-150 4x4 Crew Cab Pickup Truck (A61573)
2012 Ford F-150...
300 Gal Fuel Tank (A64119)
300 Gal Fuel Tank...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A59905)
2018 FREIGHTLINER...
2017 Ford Explorer AWD SUV (A61574)
2017 Ford Explorer...
2019 JOHN DEERE XUV835R GATOR UTV (A64280)
2019 JOHN DEERE...
