Deck clearance for hay wagon?
/ Deck clearance for hay wagon? #1
drewlamb
Calais, VT
Kubota 4400
Just got my first running gear for sap gathering (a 6x10) and am building a deck - 2x6s on 4x8 stringers. I want the deck as close to the ground as possible so I want to minimize the clearance between the top of the wheel and the deck. How small can I go? I was hoping to get away with no more than 2 inches.
Thanks!
/ Deck clearance for hay wagon? #2
Need some more info. Sap gathering involves a tank/drums on the trailer I presume. Depends on what trailer you have 4 wheel with front turning or two wheel?
For all practical purposes you can build inside the wheels and make arches around the wheels putting it closer to the ground.
But in general there is no reason you would need more than 2" clearance - maybe a picture of your wagon, rig and sap tanks you plan on using would give us a better idea and prompt more replies/solutions.
Carl
/ Deck clearance for hay wagon? #3
we build our wagons with about 2" clearance, there is no suspension so it seams to work well, never had a problem yet. I have had trouble with bigger tires, I usually buy old truck tires whatever the tire shop has on hand and if they are too big they cause trouble on 1 of my wagons.
/ Deck clearance for hay wagon? #4
I'd give it an inch - you can always put a block between the running gear and stringers if you someday get bigger tires.
Thanks guys. Gonna go for 2". This was my first post on TBN (do people call it that?), and it's great to get helpful advice from knowledgeable and experienced tractor users!
2014 CATERPILLAR 938K WHEEL LOADER (A65053)
2014 CATERPILLAR...
2023 Takeuchi TL6R Compact Track Loader Skid Steer w Low Hours (A63689)
2023 Takeuchi TL6R...
2020 VOLVO EC200EL EXCAVATOR (A64279)
2020 VOLVO EC200EL...
2007 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A65643)
2007 DRAGON 150...
Kinze KPM3 Planter Monitor (A65640)
Kinze KPM3 Planter...
(1) New 7ft Chain Sling (A65579)
(1) New 7ft Chain...
