Decision Time: Kubota RTV. Need advice
   / Decision Time: Kubota RTV. Need advice #21
I've had my new 2014 RTV-X900 for 2 months now. The 'stuck shifter' problem has me about ready to ship machine back to Japan. Nothing seems to help and it's getting worse. When the shifter becomes stuck in gear, only shutting off engine will free it up.
I'm having another conversation with the dealer tomorrow.
My 2014 RTV1100C had a shifter issue but my dealer came out to my place a corrected it.
   / Decision Time: Kubota RTV. Need advice #22
   / Decision Time: Kubota RTV. Need advice #23
Shifter is an issue on the new x900 but I just tap the gas pedal a little then shift it in gear. Just like slipping the clutch in my younger days. No it shouldn't be that way but this vehicle is so much nicer than my old 2009 kawasaki 4010 mule.
Thanks for all the replies. I am still on the hunt; I'll let you all know what I come up with. :thumbsup:
   / Decision Time: Kubota RTV. Need advice #25
Shipping it back to Georgia USA would likely get better results.
David Kb7uns
   / Decision Time: Kubota RTV. Need advice #26
I think they are too slow. I would be a lot more content if they topped out at 40mph. People with larger acreages and farms here and there would benefit much more with higher ground speeds.
How are these units in mud? I had someone tell me they're underpowered and terrible in mud. The guy said he can't hardly spin his wheels to get out of mud?
As I was told back in 2007 when we got the RTV1100 was that to go above the 25MPH speed it would make more Federal vehicle safety standards kick in.
David Kb7uns
   / Decision Time: Kubota RTV. Need advice #27
I purchased an RTV900 in 2010 with about 3000 hours on it and have since added another 210. It has a plastic roof over the cab, a dump bed, and 1 7/8" trailer hitch (since changed to 2"). I had to fix a leaking coolant fitting in the head, replace the front drive shaft, replace the rear u (CV?) joints, and tires. The previous owner had beefed up the bed with tread plate and angle iron, then slapped a coat of gray primer over the whole mess, so it's no beauty queen but it works hard. I've had almost a yard of gravel in the bed many times, so much I had to give the hydraulics a little lift by hand to get it moving. As others have mentioned, it's no speed demon, but it'll climb any hill where there's enough traction. I think that the Carlisle AT489 ATV tires I put on it are better for traction, but the Kubota tires are rated for higher loads and are probably tougher around rocks and field debris. Kubota doesn't sell replacement tires, only complete wheels. That's probably because it can be very difficult to get the beads to seat. I had my local tire guy order the tires and his men spent several hours trying to seat those beads. Shifting is only a problem when the drive train is loaded, such as when stopped on a hill. On level ground with the brakes on it shifts easily, but can seem to get stuck in gear if it has just been climbing/descending. Only cure I've found is either to plan shifts in advance for level ground or failing that, to somehow unload the drive train, usually by going down hill and applying the brake to stop. But that can be a problem if you're headed up hill and need a lower gear to make progress, especially since the shift lever won't even move into neutral. In situations like that blipping the throttle sometimes helps, as does rocking the steering wheel. With enough persuasion on the shift lever I've always managed to get it to where I want it. I do the oil/filter changes regularly, and other than the u-joint issues, the only other problem I've had is a stick that holed the radiator. A local shop was able to braze the hole and it's been fine ever since. Other than that I've had no other problems with it. One modification I've been considering is moving the air intake over to use the roll cage, as the stock air intake is right in front of the rear wheel and really sucks up the dust. The only real shortfall I'd complain about is a lack of power. The driveway here climbs a 300 foot hill to get to the mail box a quarter mile away, and speed drops by at least half in the steepest part of that climb. That's just the hydrostatic transmission doing what it's supposed to, but the one time I tried to keep up with a friend on an ATV I was literally left in the dust at the first hill. If I had it to do over again I'd also look at the John Deere Gators, but since I've yet to even sit in one, I can't comment if they're better or worse than the RTVs.
Hi Guys,
We ran over to a local Kubota dealer that has a 2013 1100 with sliding windows (nice) and radio/CD (nice but not a necessity). the unit has 23 hours on it and was taken in on trade for a new tractor. The story is the original owner bought this last November to look over auction property...anyway, the unit is like new with about 6 months left on the warranty. I asked his bottom line price if I paid cash on the barrel head. He hemmed and hawed for a bit then comes back at 16,900; he was asking 17,500.
That seems like a small drop, so my question to you all is...twofold....first, how bout that price? I am finding some 2012 and 2013 with under 100 hours that are in the 14.5k to 15.9k ASKING price.
Second, I was wondering opinions on a new 2013 unit. I get zero financing and I don't get the independent rear suspension that seems to be the latest buzz. I would like one with the sliding windows. Also, I don't know what kind of $ we're looking at vs the 16.5k price, so...opinions gentlemen?
Michael
   / Decision Time: Kubota RTV. Need advice #29
Sounds like you know the features of the various years and local prices...asking. Prices vary by region so it's hard to tell. I'd not be worried about anything that has 100 or less hours on it assuming it is in good condition otherwise and you believe that the maintenance has been done on it. Features have a way of being either completely unnecessary....or amazingly convenient and used every time the vehicle is used. Decide which ones you will be using very frequently and pay the least you can for those. I've found that Craig's List has occasionally had a good deal...but only trade with somebody you can SEE and after you have DRIVEN the particular vehicle...scams for RTV'S abound on CL.
When I was pricing my RTV, I got quotes from about 6 dealers and they varied by about 3000 dollars....I'm assuming you have been to several dealers and priced exactly the same thing??
   / Decision Time: Kubota RTV. Need advice #30
I was quoted 20130 for a loaded 2014 model.
JOHN DEERE 544G WHEEL LOADER (A58216)
JOHN DEERE 544G...
2022 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A56858)
2022 Chevrolet...
2137 (A58376)
2137 (A58376)
2016 SHADOW CRUISER (A58214)
2016 SHADOW...
2016 Ford Explorer AWD SUV (A56859)
2016 Ford Explorer...
INSPECTION (A57453)
INSPECTION (A57453)
