Decent quality grease gun?
   / Decent quality grease gun? #41
Thread might be better placed ion the Tools section.
How does LnL differ from the regular tips? I don't see much difference in the pictures on their site.
I have a couple from HF that work fine and a couple of older ones from who knows where. One of those is plugged up and I need to find a way to dissolve whatever is in the metal tube ... maybe mineral spirits?
All my battery tools are Ryobi and I haven't found a grease gun from them yet.
   / Decent quality grease gun? #42
SKF Lincoln 5900 PowerLock coupler is similar design as lock n lube and cost less
   / Decent quality grease gun? #43
Well the grease gun was what I was referencing. It takes screw in cartridges versus standard grease cartridges. A lot less mess.
   / Decent quality grease gun? #44
   / Decent quality grease gun? #46
   / Decent quality grease gun? #47
All good points!! The tubes are refillable. And the tip style is the same clam shell clamp as the other brands. We sure like it!
   / Decent quality grease gun? #48
I have Lincoln battery operated with two batteries so one is good when i need it, easy to use and change grease tube
   / Decent quality grease gun? #49
Same. I have more Ryobi than you can shake a stick at. But they dont make a grease gun. Submitted a few requests over the years but still nothing.
I ended up getting a Dewalt. It works well with that 3' flex hose on it & the variable speed cordless is nice. Not sure if I like the longer LnL XL I got over the normal LnL, but it's better than the standard couplers.
   / Decent quality grease gun? #50
For a single hand operated grease gun I will ad a vote for the John Deere Heavy Duty Pistol Grip Grease Gun TY26689 for $35.99 at greenfarmparts.com. It has a pressure and volume setting and is probably the same one mentioned in posts 13 and 16.
3PT SCRAPE BLADE W/ TEETH (A58374)
3PT SCRAPE BLADE...
LOT: (2) Shelving Units w/Equipment Parts & Hardware (TANKS NOT INCLUDED) (A59076)
LOT: (2) Shelving...
2004 Freightliner FL60 Ambulance (A56858)
2004 Freightliner...
2017 Ford Explorer AWD SUV (A56859)
2017 Ford Explorer...
PORTABLE HAY FEEDER TRAILER (A52708)
PORTABLE HAY...
2015 Volvo VNL 64T (A55315)
2015 Volvo VNL 64T...
