Decent 84-96" rotory cutter
   / Decent 84-96" rotory cutter #1
inode
Tennessee
Kubota M7060HD12
Who puts out a decent rotary cutter that's heavy duty for less than $3500? I've been looking at TRI, Titan, Big Bee and a few others.
   / Decent 84-96" rotory cutter #2
Did you get a quote on the TRI? I like their 8’ HD model but haven’t shopped around yet.
   / Decent 84-96" rotory cutter #3
I consider the Brown 600 series rotary cutters to be heavy duty. The Brown 684 is a very capable heavy duty cutter - will cut trees up to 4" - has a 145 hp gearbox - - lists for $8285.
The Brown 410 series rotary cutters are medium duty. The Brown 418 will cut trees up to 2"- has a 130 hp gearbox and lists for $5455.
Honestly - you will not find a rotary cutter that is considered to be heavy duty - in any width - that lists for $3500 or less.
   / Decent 84-96" rotory cutter #4
Whats your location? Ive got a RCR2684 in great shape for sale. IMG_1042.jpg
   / Decent 84-96" rotory cutter #5
How much are you asking for the RCR2684 Rmart30?
My recommendation would be the Rhino 272 or the 284 slightly higher.
   / Decent 84-96" rotory cutter #6
$2950
   / Decent 84-96" rotory cutter #7
Look for a used Rhino Turbo 96. I found mine for under $4k...used 3 times20181026_120043.jpeg
   / Decent 84-96" rotory cutter #9
Look for a used Rhino Turbo 96. I found mine for under $4k...used 3 timesView attachment 577272
How much clearance can you get under the deck? I have a stream with a hardened crossing that divides my property. Being able to clear that creek has been my main concern with a towable cutter opposed to a 3pt.
   / Decent 84-96" rotory cutter #10
In this photo, it is resting on the transport stop. It will go up another 5 inches or so.
2003 Volvo L60E Wheel Loader w/ 3 in 1 Bucket (A59213)
2003 Volvo L60E...
2015 Liebherr L542 Articulated Wheel Loader (A56857)
2015 Liebherr L542...
55-Gallon Drum of Komatsu Hydraulic Oil HO 56-HE (UNOPENED) (A59076)
55-Gallon Drum of...
2005 CAT D6N XL Crawler Dozer w/ 6 Way Blade (A59213)
2005 CAT D6N XL...
2021 Bobcat E50 R2 Series Excavator w/ Push Blade & Hydro Thumb (A59213)
2021 Bobcat E50 R2...
2018 CATERPILLAR 299D2 SKID STEER (A52709)
2018 CATERPILLAR...
