Dealing with high rows
/ Dealing with high rows #1
corey9212
Platinum Member
Red Deer County, AB
2015 John Deere 3046R
Hello, I've been reading about when using a blade the edges get high and can cause drifts, I am now experiencing the high edges causing the drifts and am wandering how you guys deal with it? Do you just remove the top to lower the edge? Or do you remove the pile all together making the drive wider? Do you use the blade to do that? Or do you use a bucket? It will be interesting to see how everyone handles the high edges.
/ Dealing with high rows #2
I bucket mine back six feet or so if they start collecting snow.
I try to pile and blow snow on what is 90% of the time, the downwind side of the driveway.
I bucket mine back six feet or so if they start collecting snow. I try to pile and blow snow on what is 90% of the time, the downwind side of the driveway.
Do you bucket all of it or just a layer off the top?
/ Dealing with high rows #4
I do exactly what Dave does. I bucket all of it not just a layer off the top. May not be as practical for those with really long drives.
/ Dealing with high rows #5
I don't try for bare ground, but most of it gets shoved back.
If we are having a snowy winter and the piles are growing out of control, I go out on a nice sunny day and do some clean-up and re-arranging. Sort of prepping for the next heavy snow. As spring gets closer, I worry about it less. Having a blower is a big help. I used to do everything with just the bucket.
When you bucket it do you completely move it or just push it over? I move it to my designated snow pile that's 100 yards away but find that when I move it, it makes a mess of the drive I'm not sure if it's cause of my technique (I run the bucket the length of the drive skimming the edge off.)
/ Dealing with high rows #7
It depends on how much snow I have lying on the ground. First few snow falls never had a problem just back blading it to the side of the drive going forward. Once the banks get 2 feet high, I either have to run in reverse and blade it off farther, or herringbone it off using the FEL & bucket. I'm a wimp and prefer to do my plowing only once per storm, so I usually wait until it's over before clearing. Got one storm that was so deep and heavy that I had no choice; I couldn't blade it and had to herringbone my way down the entire drive.
What is herringbone? I've never heard that term before.
/ Dealing with high rows #9
This is a barn, but it could be your driveway. :)
The center is the driveway. Each cow is a loader push, making a herringbone pattern.
Bruce
/ Dealing with high rows #10
I also will go out a couple of times in the winter and plow a snow fence. Actually i use my blower for that. It keeps the drive clear on windy days between storms.
/ Dealing with high rows #11
I used to access my place across a east - west road that was nearly 1 mile long. The prevailing wind in the winter is from the north. I would blade my wind rows to the south and start with a 50' wide path. By spring my road was down to 18' wide. If you don't start wide, you will be screwed. Herring boning is only a tempory fix because it increases drifting. Have a look at how they better guys clear oilfield access roads.
TAYLOR S/A LOOSE LEAF TRAILER (A64278)
TAYLOR S/A LOOSE...
2024 JOHN DEERE TURF GATOR TX 4X2 UTV (A63276)
2024 JOHN DEERE...
Small Cowboy Statue (A64557)
Small Cowboy...
2015 Chevrolet Tahoe SUV. (A64557)
2015 Chevrolet...
14in Bucket w/ Teeth Excavator Attachment (A64194)
14in Bucket w/...
2005 20 Ft. Grady-White Boat with 25 Ft. Float-On T/A Boat Trailer (A64557)
2005 20 Ft...
