Dead Battery Problem: Nugget!
/ Dead Battery Problem: Nugget! #11
I had what I thought was a bad battery on my lawn tractor. I would go out to start it would not turn over the tractor and I would have to charge the battery. It would even happen after it had been running a while. I bought a new battery and it was fine for a week, then the same thing happened.
I took it to the dealer because it was under warranty. He said the valves needed adjustment and because of that, there was a lot of back pressure which made it hard to turnover which seemed gave it weak battery symptoms. He said charging the battery must have given it just the little more power it needed to turn it over.
I haven't had a problem since and I still have the original Deere battery. (4 years later), With the replacement sitting on a shelf.
/ Dead Battery Problem: Nugget! #12
Had that same problem.. bought 3 batteries and 1 starter before I read about it, and set the valves myself.. fired right up Briggs and Stratton OHV engines. common problem. Still have the new starter, dont have the mower anymore, starter is brand new in the box, just put in on and tried it, and took it right back off.. buy you cant take them back.
James K0UA
iDrive TDS-2010H...
1992 Talbert 70 Ton Lowboy Trailer with Removable Gooseneck (A61307)
1992 Talbert 70...
Deere 350G LC (A53317)
2020 DRAGON ESP...
2015 GENIE GTH-1056 TELESCOPIC FORKLIFT (A52709)
2015 GENIE...
Sellick S80 (A60462)
