Dead 2004 Model A Toolcat
/ Dead 2004 Model A Toolcat #1
yooperdave
Veteran Member
Luxemburg, WI
Tool Cat 5600, LS XJ2025H, Branson 4215HC
My 2004 Model A Toolcat has been sitting in my shed for quite awhile. It used to run and then choke out of fuel and die. It would restart and I was good to go again for a couple hundred feet and would die again. I got it to the shed and there she sat for a few years. I put a new battery in it and tried to start it up. The glow plugs would not activate and ALL the idiot lights would flash in unison while turning the key. I just had the fuel filter changed before the last round of issues. Would like to take it in, but need it to work for a few minutes to load it onto the trailer, as pushing or pulling is not an option.
Any ideas? TIA Yooper Dave
/ Dead 2004 Model A Toolcat #3
Load test the new battery, if it is ok, double check that you have all the connections correct, and they are clean and tight.
/ Dead 2004 Model A Toolcat #4
If it has a 3 wire pull and hold fuel shut-off solenoid, maybe the hold isn't holding for long. Do you have codes? Is it shutting down because low oil pressure or fuel pressure?
