DC to AC power inverter to run electic tools?
   / DC to AC power inverter to run electic tools? #41
</font><font color="blue" class="small">( I am confused? About the 17 amp thing. It takes over 167 amps DC to get 2000 watts AC right not 17 amps DC to get 2000 watts AC.
George )</font>
Yeah, 167 amps at 12 volts is 2k watts. And that's not allowing for the inverter's inefficency.
But 2K watts at 120 volts input, rather than 12 volts, only requires 17 amps. In the case of the JD unit, is it an inverter, or is it using the AC produced by the alternator?
I'm going to go back and re-read a few posts.
According to the JD website, it is using an inverter. I cut and pasted the actual wording somewhere up this thread.
   / DC to AC power inverter to run electic tools? #43
Bob,
I have a 1500 W inverter. It uses a 12 V trolling motor battery, which is charged by a 40 W solar panel. My 1500 W inverter regularly powers a honking big shop vac, an air compressor, a battery charger for my cordless drill, a disc grinder. It is good for tools up to 13 amps, which will work on a 2 HP motor. Every time I use the inverter, I am tickled to death. Yes, I believe it would be worthwhile to have one on your tractor on a large spread. You can now (DRAT!!) get a Coleman 2000 W for $200. This would be good for up to 18 A tools.
   / DC to AC power inverter to run electic tools? #44
Re: DC to AC power inverter to run electric tools?
I am still confused as to what the net effect of running a 1500 watt/3000 watt surge inverter would be off the battery, with the engine running on my tractor.
-- Will it draw down the battery too much?
-- Will it overload the alternator?
-- Would I be better off running it with the engine off for shorter periods of time?
)</font>
Bob,
A 2000W inverter is not a big load on your battery unless you use honking big tools that draw above 15 A. Tools like a 4" disk grinder (8 A) can be run a long time without draining the battery too much. A 3/8 drill can run intermittently all day without problems. Most inverters produce 110 V, which reduces the wattage considerably from 120v, and thus the amperage drain on the battery.
As you indicated elsewhere, tools are normally used in short bursts. Constant use of a big tool can quickly drain the battery, but you can get a feel for this.
Always shut down the tractor when using the inverter, and crank it for a quick charge if you suspect the battery is getting below 75% capacity. Frequent deep discharging of a battery (below 75%) will shorten its life. Yes, below 75% is considered "deep".
Charging a battery will never hurt your alternator.
Inverters are cool. I'll never be without one again.
Do the new Coleman units have an automatic shut down if the battery drains too low? I have been looking at a couple different brands and both of them have an auto shut down to prevent discharging the battery too much so that you are ended up stranded in the field with a dead tractor battery.
If the tractor is running will that cause the inverter to damage the alternator?
   / DC to AC power inverter to run electic tools? #46
</font><font color="blue" class="small">( Do the new Coleman units have an automatic shut down if the battery drains too low? I
If the tractor is running will that cause the inverter to damage the alternator? )</font>
Bob,
The Coleman units at least have an alarm, and I'm 99% sure they shut down when the battery voltage gets low. I would be afraid to run a larger inverter while the key is turned on, but I may be wrong.
   / DC to AC power inverter to run electic tools? #47
Charging a deeply discharged battery will kill the alternator in time, trust me I know. Been there done that many times over. Take a look at your alternator it is a very small unit and if asked to produce maximum output it will generate lots of heat and wear out the bearings, brushes and diodes. My experience has been that the bearing or is it the lubricant for the bearing burns out and cause the unit to seize and bust the fan belt. On a modern Suburban it can be fatal if the engine is allowed to overheat after the fan belt goes south since it only has one belt for all. Here at work lots of guys have inverters in their own cars to watch TV and such. Common problems are dead batteries and done in alternators and oh yeah “dude can I get a jump”. On my NH TC 24D the alternator looks fairly simple to change out but I bet you the price is 200 bucks for the little thing. I have been tempted to hook up a winch to my tractor but know that the 200-275 amp draw might end up killing the battery and alternator but I have not ruled out installing a larger one but that would require letting New Holland off the warranty hook. So once again how about a cheap PTO gen? You get 5K and more and you can still run your tractor at high RPM’s. /forums/images/graemlins/grin.gif
Don’t get me wrong I like inverters and “inverter trucks” but they require lots of maintenance and can be problematic. Many of you are right about using them infrequent but heed this warning, run the tractor engine you will need all the power you can get to keep that inverter going or you will be buying new batteries often. We hardly ever run just off the batteries. Why because it kills the alternators and can be murder on the batteries plus it gets hot in the trucks /forums/images/graemlins/tongue.gif
George
   / DC to AC power inverter to run electic tools? #48
Bob, I have 2 inverters.
1. Tripplite PV600. Used to run a TV and Satelite receiver. Not used on tractor but a few times.
2. PortaWattz 1000. Used on the tractor to power paint sprayer (Wagner) and small power washer as well as other small tools. It is not permanently connected to tractor battery. I use 2/0 welding cable with 400 amp clamps when connecting.
Using the power washer causes the most drain so I have to be sure and let it shut down periodically. I use it to clean fencing and such.
   / DC to AC power inverter to run electic tools? #49
</font><font color="blue" class="small">( a battery charger for my cordless drill )</font>
Yikes... inverting dc to make ac.. to xformer it back down to dc to charge a coordless drill battery.. probably about the highest loss situation I can imagine.
Any chance you could get that cordless drill charged direct dc... cut out the middleman per se. Since something like charging that cordless drill battery is going to be a long process you are chewing up that storage battery capacity in the mean time. Even though the load from the charger is probably real negligable.. the onstate current draw from that inverter is still substantial. In other words.. just the inverter running, open loop, with no 12v appliances plugged in, there is still power being used, ...
Would be much more eccicient to rig up a dc charger either utilizing that high dollar 40w panel, or with the addition of a cheap add on solar charger available at tractor supply, or harbor freight....If your unit is 12v or lower it would be super easy.. if it is 14.4 or 18v it is still doable,... just need a bit more hardware. ( harbor freight has a panel that floats from 19$ to 9$ every now and then. It is rated at 12.5vdc @ 125ma... but will produce up to 22 volts in direct sunlight.. at a lower current.. like 45-65 ma... slow charge.. but if it has a week to set.. that's the ticket. Add a panel in parallel or series with a bit of support hardware from radio shack and you could have a still cheap and easy charger, for the 14.4 and 18v models ( A constant current charger using those panels and a handfull of diodes is real easy... ).
Soundguy
   / DC to AC power inverter to run electic tools? #50
I have a question relating to this subject. What if a person hooked a UPS (Uninterruptible Power Supply) after an inverter and plugged the power tool into the UPS? The new UPS system I just got has lighting and surge protection. I assume these units have some form of "power conditioning" also. If I ever had to power my computer off of my generator I always planned on hooking the generator up to the UPS and not directly to the computer.
Does hooking up a generator to the UPS and not the computer directly offer any additional benefits? Any downsides?
Would hooking up a UPS between an inverter and a tool offer any benefits? Any downsides?
Just wondering,
Spence
   / DC to AC power inverter to run electic tools? #51
You want to be careful using an inverter to charge power tool batteries. Many of the chargers can't deal with the modified sine wave. I have a 2,200 watt (2,600 for 20 minutes and surge to 4,400). It will charge my power tool batteries but never fully. One of my batteries (18 volt) now has a very short life; and I think it is because I used the inverter twice to try and charge it.
Bob
At my office we have an emergency plan for power failures. We run the generator to a large UPS and the UPS then powers our main computer. It does "condition" the power coming out of the generator. So you will protect your electronic equipment from spikes, surges, low voltage, etc. Most UPS systems are specifically designed to provide safe power for computer and electrical equipment. Most are also very small and don't offer much run time, but that is not always a big issue.
At my home I have my electronic equipment (satellite upfeed, computer network, etc) powered in a very similar manner. Generator to the back up panel, panel to the UPS, UPS to the equipment.
The biggest downside to using inverters and even UPS units is that there is an inherant lack of efficiency. A typical inverter is probably 90% efficient. I have not checked the UPS units, but as they are battery back up units, I suspect they probably are also sapping off some efficiency so maybe they also run at 90%. If you are generating 5000 watts and you lose 500 of those to the inverter and then another 450 to a UPS unit, you gave up a large chunk of your available power.
Now if you run an inverter off your battery and then plug a UPS into the inverter and then try to run a power tool off the UPS I am not quite sure what will happen. I think that something like a 13 or 15 amp circular saw might simply drain things down pretty quickly, which is the original question I was posing in this thread. I just don't quite know how quickly. A simple 3/8ths hand drill might only draw 3 or 4 amps and should run for a long time without much problem. But your question of tossing in a UPS after the inverter might end up altering things a bit. I doubt if it would alter it too much. And if the UPS is not designed for the draw of an electric motor, the surge in the demand might ruit the UPS??? I just don't know that there is enough advantage to it to mess with it.
I am probably going to add a 1500 watt inverter to my tractor. I have figured out that the battery should be upgraded, but I will probably wait to do that until the current battery won't hold a charge. And near as I can tell, I don't want the tractor running while using power tools because it will strain the alternator.
   / DC to AC power inverter to run electic tools? #53
There are basically 2 types of UPS's. Those that stay in standby offline and those that power the device hooked to them. The standby units have a small interruption when switching on (although only a few nanoseconds). They have no conditioning. The full on units condition and have no lag. Which unit do you have? It's hard to say. If it says it has conditioning then it's probably a full on unit. Lightening & surge protection alone usually provide no conditioning.
The only downside to hooking up the UPS is that you use some power to run the electronics of the unit that could otherwise be used to power the tool.
   / DC to AC power inverter to run electic tools? #54
First.. there are some incompatibilities between the stepped output of some inverters and what your ups is expecting to see.. speciffically ferro-magneting inputs.. of some of the older designed ups's.
Second, keep in mind that there is a power loss in that extra step.. though i believe you would do better with a line conditioner after the inverter / generator. the line conditioner, like APC's Line-R is essentially the good parts of the ups, minus the inverter and battery. When I ran my electric repair business I used to be a dealer for the apc products.. fairly decent.. though their ups's, like many others, wont start a load on the otuput with having an acceptable input voltage that they were first running on before 'hand-over' to battery... If they sense a site fault.. like no ground reference, or reversed neutral, or low/fluxuating voltage.. they may not come on.. etc... I had no luck running the old 250's and 200's off a genny.. they showed site wireing faults, and like I mentioned.. even the new office-ups series won't start a load with no input... they really were only designed to maintain an existing load after handover from line to battery powered inverter.. etc.
good luck though.. you are in the right fram of mind.. I wouldn't run any sensitive electronic equipment direct off a genny output... some soret of emi/rfi and pahse correction, clamping/clipping, etc needs to be present..
Soundguy
   / DC to AC power inverter to run electic tools? #55
</font><font color="blue" class="small">( There are basically 2 types of UPS's. Those that stay in standby offline and those that power the device hooked to them. The standby units have a small interruption when switching on (although only a few nanoseconds). They have no conditioning. The full on units condition and have no lag. Which unit do you have? It's hard to say. If it says it has conditioning then it's probably a full on unit. Lightening & surge protection alone usually provide no conditioning.)</font>
Most APC ups's, smaller than the matrix ups's, and the non smartups's, are all standby models.. and all offer power conditioning... and common, normal mode filtering / clamping, and clipping / surge protection..., as well as efi / rfi filtering... and ground fault detection..( though i doub't they do any phase correction while in standby ). The line-r model line conditioners run isolation, on a multitapped transformer.. so there is considerable filtering.. both by natural inductance, and via voltage adjustment via taps, etc... very quick handover times.... catches even before direct triac powered ( transformerless ) powersupplies crap out on the dropped sine wave.. etc.
Soundguy
   / DC to AC power inverter to run electic tools? #56
Soundguy, thanks for sharing your knowledge. I have another question that you may be able to help me with. I just bought a new Hewlett Packard laptop computer. I had an older HP that just couldn't keep up with me anymore. I had a DC power supply for the older HP that I got directly from them. It was an auto/airline adapter that put out 75 watts. HP does not make an auto/air adapter for my new laptop because it requires 90 watts of power. HP tech support is telling me that I should use a DC to AC inverter like we have been talking about in this thread. They told me to plug the AC power supply that came with the laptop into the inverter and use it like that. I do have a 175 watt inverter that I picked up on clearance a while ago for $13 but I am not sure I want to hook up my new laptop to it. I don't like the thought of converting the DC voltage from my van to AC with an inverter and then converting it back to DC using the laptop power supply. I would prefer to use a DC power supply from the van to the laptop and skipping the AC conversion. Unfortunately it doesn't sound like HP is going to be making any 90 watt auto/air adapters. Best Buy had a Targus Universal Auto/Air Notebook Power Adapter for $99 that looks ok.
What do you think? Am I correct in thinking I am better off with the Targus or similar DC power supply? Would it be fine to use the cheap VEC023 MAXX SST 175 WATT POWER INVERTER that I picked up for $13. I am assuming that having the battery in the laptop while using any external power source is always a good idea.
I travel around the country by van and I use the laptop for GPS/mapping navigation. My older HP worked great for around 4 years on that HP Auto/Air adapter. I sure don't want to do anything to harm the new laptop or the laptop battery. I also don't want HP to tell me something insn't covered under warranty because I used a aftermarket power supply.
spencer, I looked at the Targus models but bought, for about $119 the iGo model.
It has been used to power 4 different laptops (3 different brands) and also has adapters (at an added cost) to power cell phones. Like the Targus, the iGo unit powers laptops on airplanes in cars and also direcly from an normal AC outlet. It comes with about a dozen different connectors so it will power almost any brand of laptop from an Apple to a Zenith. It was highly recommended to me by Apple and Compaq (which is a division of H.P.).
   / DC to AC power inverter to run electic tools? #58
You are correct in assuming that multiple conversions will yeild multiple losses.. however in this situation.. it isn't too bad an idea. That small inverter won't run 175 watts all the time.. it will run according to its load.. pluss any losses in conversion..
Obviously that hp charger isn't passing 12v to the computer.. but rather something stepped down like 5v or 7.5v.. and they don't want to run a hi wattage resistor.. etc... so their answer is to use the available home adapter.
If it is a transformer style adapter.. you'r home free... it won't bee to picky if your inexpensive inverter is stepped sine wave ( or even square wave.. ). If it is a triac based power supply.. it may not be as efficient.. but will still work fine.
I'm guessing the hp ac adapter has some filtering built into it.. so that actually gives you a layer of extra protection you might not have on a direct dc hookup.. etc.. ( in case your alternator decided to dump 18v out all of a sudden.. etc
Anyway.. I've done the same thing you are mentioning.. or similar anyway.. I has a small upsonic ups, and the battery died in it.. I removed it, and made a big cigarette lighter cord and hooked it up that way ( battery was a 12v.. etc ).. and used that as my 'car inverter' for years for my computer.. etc. I made and recycled all sorts of junk back when money was tighter and junk was more prevalent.. and easy to come by.. broken.. for cheap / free..
Soundguy
   / DC to AC power inverter to run electic tools? #59
5030,
You are right about starting current for an AC INDUCTION motor. Most small tools are universal motors. This means they have brushes and if were not for the variable speed switch they would run on AC or 120 DC. The best part about universal motors is that the starting amps is not 5x as it is for an induction motor.
Circular saws and drills will be universal motors, but air compresssors and standard table saws will probably have induction motors.
For an inverter system, get one that is at least one size larger than you think you will need.
They are cheap on ebay right now. search for "coleman inverter"
   / DC to AC power inverter to run electic tools? #60
Bob, I am an electrical engineer, but that does not mean I know everything about electricity. Here are my comments with no guarantee:
1 Use heavy gauge (2/0 that's with 2 zero. This is bigger than 2 gauge wire, much bigger. The inverter should have a recommendation, and it may suggest bigger wiring, then do it.
2. Keep this wire short between the battery and inverter, one or two feet if possible. Connect the inverter directly to the battery. Current will be over 100 amps. Keep the inverter cool.
3. A separate battery say 100 ampere hour or bigger paralled with the other one could be located in a separate location. this is not a bad idea, but may not be needed. Run the big wire between the inverter and the second battery and some slightly smaller wire directly to the other battery. I cannot give you an exact size but 6 gauge is rated at 55 amps continuously and should do. I don't know your tractor, but this sounds kind of extreme.
4. Instead of 3, put the largest battery that you can in the existing battery box and wire the inverter to it as described in 2.
5. Rev the engine up during and after use. The tractor alternator will only put out its full rated current at high speed. It will not charge the battery at full alternator rated current. Lead acid battery cannot be charged quickly with present technology.
The saw or almost anything with an electric motor draws a lot of current at start up and a lot less at no load. As you try to cut the current will go up. Start the saw unloaded and let it get to full speed before cutting wood. Don't load it too much.
Other options: Dewalt sells a battery charger for their saws and drills that can run off of a car cigarette lighter. This would be easy to add to the tractor. I have used their 18 volt saw to cut 2 X4. I think they claim 72 or so cuts per charge.
If you have not done wiring like described above, get an electrically knowledgeable person to give you a hand. I hope this is helpful, the inverter manual should have some good tips and they know their equipment best. You might want to give them a call and listen to their advice. Make sure that they are comfortable running a saw with it.
Good luck and be safe, a shorted tractor battery can put out several thousand amps if shorted and you don't want to be there when it happens. It can also explode. When you parallel batteries they must be connected postive to positive and negative to negative. It reversed an explosion might occur.
20 UTILITY TRAILER (A58214)
20 UTILITY TRAILER...
2015 CASE 621F WHEEL LOADER (A58214)
2015 CASE 621F...
Truck Mounted Carpet Cleaning Extraction Machine (A57454)
Truck Mounted...
2021 MULTIQUIP 25 WHISPERWATT AC GENERATOR (A59823)
2021 MULTIQUIP 25...
2018 INTERNATIONAL 4300 26FT NON CDL BOX TRUCK (A59905)
2018 INTERNATIONAL...
PALLET OF 15 4 X 8 GROUND PROTECTION MATS (A58214)
PALLET OF 15 4 X 8...
