dash panel
/ dash panel #1
tonyw
NC
YM1401d
ugh! I know I'm asking too many questions, but I need to replace my oil light. Is there any easy way to remove the dash panel without tearing everything else apart in a 1401d? /w3tcompact/icons/hmm.gif
thanks again!
/ dash panel #2
the light bulb should be removeable from the back. If I remember, I usually reach under the dash with the hood up and replace them.
/ dash panel
I'm not sure, but it seems like they aren't easily accessible from the back--you mean inside the engine compartment, right? hopefully, I'm wrong--I'll check it out tonight.
thanks
tonyw
/ dash panel #4
Tony,
On a 1700 the bulbs are all in one little piece that unsnaps from the unit that is fastened in the dash. If I pull it out, all the bulbs are accessible.
/ dash panel #5
There is a removable panel below steering wheel on back of cowling. Its above shifter. 5 phillips head screws.You can access most parts there.
/ dash panel
Thanks, everybody, for your suggestions; I believe I have figured it out. /w3tcompact/icons/smile.gif
/ dash panel #7
Tony you can't ask too many questions here thats why we are here. /w3tcompact/icons/smile.gif
Chris
MacDon 963 Draper Header (A63688)
MacDon 963 Draper...
JOHN DEERE 7100 4R PLANTERS (A63291)
JOHN DEERE 7100 4R...
HURRICANE (10) DRAWER (A64280)
HURRICANE (10)...
Case 1083 20ft Corn Head (A63118)
Case 1083 20ft...
(2) 480/80R50 TIRES ONLY (A63291)
(2) 480/80R50...
2021 John Deere HD35R Draper Head (A63111)
2021 John Deere...
