danged if I can figure out what to call it.
   / danged if I can figure out what to call it. #11
   / danged if I can figure out what to call it. #12
I think I'd be looking for a heavy duty box blade or roll over blade and torch what's not needed off
something like this can be found on Craigslist and such
https://www.tractorbynet.com/forums...ets-see-your-modified-box-gill5-5boxblade-jpg
I was thinking box blade w/scarifiers too... and just tilt up all the way and drop the scarifiers to max depth. I just bought a used box blade and thinking that is what I would do. A box blade if you can get the depth you need, would be a far more versatile tool in my opinion.
   / danged if I can figure out what to call it. #13
I've got a ballast-roller with spiked 'bands' to aerate my ground.
   / danged if I can figure out what to call it. #14
if you're just wanting to 'aerate' that's typically just poking holes, so one of the rollers with spikes would do that fine. If you want a bit bigger hole, get one with tubes that will pull plugs out will do what you want. A scarifier or box blade with the scarifiers lowered is going to really tear up the ground, if I was going to that extreme, I'd just use a disk harrow.....
   / danged if I can figure out what to call it. #15
do you need a box blade? Buy one with scarifiers. If you already have a box blade sell it and buy a new one.
you can probably buy the teeth from EA and make your own.
WOOD GRABBER FOR MINI EXCAVATOR (A58214)
WOOD GRABBER FOR...
Computerized Wheel Balancer (New/Unused) (A59225)
Computerized Wheel...
2021 John Deere HPX815E Gator 4x4 Utility Cart (A56857)
2021 John Deere...
2021 BMW 1200RT (A55853)
2021 BMW 1200RT...
2017 Hitachi Zaxis ZX130 LCN-6 Hydraulic Excavator (A57453)
2017 Hitachi Zaxis...
LOT: (36) 14 Oz. Tubes of Premalube Heavy Duty Multi-Purpose NLGI #2 Grease (A59076)
LOT: (36) 14 Oz...
