Damaged block installing block heater L5240
   / Damaged block installing block heater L5240 #311
As you said...they should all be that way!!!
Some Kubotas have that...my B3030 was a 30 minute job.
Didn't even have to drain it. Just a "quick swap" of the heater for the plug, and lost maybe a cup of fluid.
   / Damaged block installing block heater L5240 #312
Look no piston cooling jets...
Fred
Well- at least there won't be any plugging of the jets going on... Cummins owners who swear by (at) Fram oil filters:laughing:
The cooling jet use is interesting-
wonder how many of the different scut, cut, utility tractors actually utilize them??
That may be a good thread starter- someday
   / Damaged block installing block heater L5240 #313
From the standpoint of performance, these are pretty low performance engines. I'm sure they could get a lot more power out of them than they do but at the price of durability or having to add things like cooling jets. I doubt the pistons get anywhere near hot enough to need the cooling jets.
   / Damaged block installing block heater L5240 #314
Come on, cool your jets!
   / Damaged block installing block heater L5240 #315
Hats off to you Adiredneck! I read the entire thread and kudos to you for handling the situation so well! Myself I'm not so sure, anyway keep up the hard work and update the thread as you progress. Donnie
My good sense of humor is wearing thin. My parts have been on order for 3 weeks. Now I am looking at some more bearings and more waiting and a 4th trip to the machine shop to drop the block back off and a 5th trip to pick it up when complete. I haven't had the time to even look up the new batch of needed parts. I can tell you I will not order them from the dealer.
   / Damaged block installing block heater L5240 #317
Gees- that's what was bugging me about the picture, i could see the bores but I couldn't make my brain equate that to a (normal) bottom end...:laughing:
Thats called a skirted lower and it's common today. To deck it, you locate on the machine table via the bottom of the skirt. Same applies to a line bore and counter bore.
   / Damaged block installing block heater L5240 #318
Wonder if Messicks could EXPEDITE parts procurement for your engine
   / Damaged block installing block heater L5240 #319
Every time I get a survey from Kubota regarding service work I rate them the lowest possible for parts availability and add to my complaint in the comments. It seems like every part not commonly stocked by the dealer must come from Japan. Kubota does not seem to understand down time as lost income for their customer. Your waiting for 3 weeks for any part on a tractor as new as yours is beyond unacceptable. I always cite my Cat mini-excavator to Kubota as what I consider acceptable. Any part I order from my dealer by 6:00 pm is there at 7:00 am the next day. By the way it's not the machine's fault I get to test Cat's parts service. Operator error abuse having a machine with a blade that will go through anything without getting flat tires invites abuse. Kubota - 11 days for an emergency down due to a broken loader valve control cable on my L5740 is a glaring example. Your failure is unusual enough I wouldn't expect the dealer to carry everything in stock but I would expect Kubota to be able to deliver to your dealer in no more than 3 business days.
   / Damaged block installing block heater L5240 #320
I've had great luck with Messick's. And lately Coleman has developed their online parts service. They are close to me and I got a loader pin from them in 2 days.
207274 (A52708)
207274 (A52708)
2015 Chevrolet Tahoe, 192,897 Miles, Decommissioned Law Enforcement Vehicle (A56438)
2015 Chevrolet...
2004 Mack CV713 Granite Fuel and Lube Truck (A59230)
2004 Mack CV713...
King Kutter XB 3pt Mower (A59814)
King Kutter XB 3pt...
44052 (A55852)
44052 (A55852)
1999 CATERPILLAR 312B EXCAVATOR (A52709)
1999 CATERPILLAR...
