Damaged block installing block heater L5240
   / Damaged block installing block heater L5240 #131
I have a nice Lincoln 180 Mig I bought when building my 91 Jeep YJ with my son. I'm self-taught and by no means an expert...but in the right hands a good welder and his machine can fix just about anything. If this hole can be repaired...yours should be a piece of cake!
https://www.youtube.com/watch?v=K85MH9Z5FPU
   / Damaged block installing block heater L5240 #133
Mig won't work. It's a skilled TIG job.
Wasn't implying it was a "MIG" job...that's why I posted the video of the TIG job.
But I see how it could be taken that way...my bad.
I'm home again. I got all suited up to get under my tractor to pull the oil pan, but there is no way it's coming off without pulling the driveshaft first. I didn't get my manual yet. No time last week. Is there any way to remove the driveshaft without removing the front axle?
I'll stop and order a shop manual tomorrow. Didn't think I would need a manual to removed the oil pan. I won't be able to see anything through either drain hole with my new inspection camera because they are on the side of the pan.
Anyone know how I can get it off?
Thanks
   / Damaged block installing block heater L5240 #135
If you go to Kubota Tractor Corporation - Parts List and enter your model number, you can find exploded parts diagrams of the whole tractor.
Here is the transmission-to-front axle one:
Looks like there are is a rollpin at each end (#130) that needs to be driven out of a sleeve (#20).
Aaron Z
   / Damaged block installing block heater L5240 #136
Not the same tractor.
My Kubota B7100 had roll pins and a sliding splined sleeve. Had a hard time getting it off and had to cut about 1/2 in. Of the one end to get it back on.
   / Damaged block installing block heater L5240 #137
Driveshaft removed. I think I will still need to drop the axle down a little in order to get to two of the pan bolts under the input yoke of the front axle. A socket will not fit, even a 1/4" drive.
2018 Ford Explorer AWD SUV (A56859)
2018 Ford Explorer...
500 Gallon Fuel Tank with Pump (A55853)
500 Gallon Fuel...
2012 Ford F-250 (A55973)
2012 Ford F-250...
Flat Bottom Grapple (A56857)
Flat Bottom...
2016 Ford Transit Connect Cargo Van (A56858)
2016 Ford Transit...
UNUSED FUTURE 350 HYD BREAKER HAMMER (A52706)
UNUSED FUTURE 350...
