Damaged block installing block heater L5240
   / Damaged block installing block heater L5240 #131
I have a nice Lincoln 180 Mig I bought when building my 91 Jeep YJ with my son. I'm self-taught and by no means an expert...but in the right hands a good welder and his machine can fix just about anything. If this hole can be repaired...yours should be a piece of cake!
https://www.youtube.com/watch?v=K85MH9Z5FPU
   / Damaged block installing block heater L5240 #133
Mig won't work. It's a skilled TIG job.
Wasn't implying it was a "MIG" job...that's why I posted the video of the TIG job.
But I see how it could be taken that way...my bad.
I'm home again. I got all suited up to get under my tractor to pull the oil pan, but there is no way it's coming off without pulling the driveshaft first. I didn't get my manual yet. No time last week. Is there any way to remove the driveshaft without removing the front axle?
I'll stop and order a shop manual tomorrow. Didn't think I would need a manual to removed the oil pan. I won't be able to see anything through either drain hole with my new inspection camera because they are on the side of the pan.
Anyone know how I can get it off?
Thanks
   / Damaged block installing block heater L5240 #135
If you go to Kubota Tractor Corporation - Parts List and enter your model number, you can find exploded parts diagrams of the whole tractor.
Here is the transmission-to-front axle one:
Looks like there are is a rollpin at each end (#130) that needs to be driven out of a sleeve (#20).
Aaron Z
   / Damaged block installing block heater L5240 #136
Not the same tractor.
My Kubota B7100 had roll pins and a sliding splined sleeve. Had a hard time getting it off and had to cut about 1/2 in. Of the one end to get it back on.
   / Damaged block installing block heater L5240 #137
Driveshaft removed. I think I will still need to drop the axle down a little in order to get to two of the pan bolts under the input yoke of the front axle. A socket will not fit, even a 1/4" drive.
2010 International 4300 2,000 Gallon Water Truck (A55973)
2010 International...
2022 Horizon (A55973)
2018 Chevrolet Equinox AWD SUV (A56859)
2018 Chevrolet...
air compressor (A55758)
air compressor...
2019 Peterbilt 520 Heil Side Loader Garbage Truck (A55973)
2019 Peterbilt 520...
Electric Diesel Fuel Pump with Hose Reel (A55851)
Electric Diesel...
