D45
ed3357
Central Ohio
John Deere H
I'm new to the tractor world, although I have an old tractor. I'm considering buying a D45, with front wheel drive and a loader. Mostly mowing and bailing and ground work, although I could see a need for the loader. I know it is gear drive, but more cost is important. Anyway, what are the pitfalls of this tractor, and what is a good price?
Thanks.
</font><font color="blue" class="small">( I'm new to the tractor world, although I have an old tractor. I'm considering buying a D45, with front wheel drive and a loader. Mostly mowing and bailing and ground work, although I could see a need for the loader. I know it is gear drive, but more cost is important. Anyway, what are the pitfalls of this tractor, and what is a good price?
Thanks. )</font>
The Case D45 is almost an exact copy of the New Holland TC45. These tractors are great utility tractors for mowing, loader groundwork/dirtwork, boxblading, post-hole digging, and many, many other tasks. They are not the ideal hay baling tractor and you may find them a little light for this task. If you have a small square baler and are planning on baling only a small number of bales, this tractor may be okay.
For more info, you might ask this same question in the New Holland Owning/Operating forum. That will broaden your number of responses and experience level.
I own a TC45D that is the same as the DX45, but I have never baled hay with it and would consider it more suited to pulling a hay wagon than the baler. I don't see any pitfalls to the tractor in general. If you are planning on putting a loader on it, I'd sure suggest doing that now. Your dealer can order a "loader-ready" tractor from the factory and that will save you some extra expense of having the dealer install all the hydraulics and undercarriage at a later time.
It sure is a good looking unit. I checked one out last week.
It was a auto. It's going to be a little light for what my girlfriend needs, Lifting hay bales. It would work but it would be at it's limit.
Nice unit anyway. /forums/images/graemlins/cool.gif
/ D45
I like the tractor as well. Sets up nice, and the hood slopes down so that one can see easily. I am thinking about purchasing one. My problem is that I can't get a salesman to talk to me. I laugh to myself just thinking that I am ready to buy, but the salesfolk at 2 different dealers aren't interested enough to tell me how much the equipment costs. They won't even return my calls.
I have learned alot reading the posts at this forum, and a major point that has been stressed is to buy the dealership as well as the tractor.
Thanks for letting me ramble.
</font><font color="blue" class="small">( It's going to be a little light for what my girlfriend needs, Lifting hay bales. It would work but it would be at it's limit.
Nice unit anyway. /forums/images/graemlins/cool.gif )</font>
Scott, what size bales does your girlfriend have? I use my TC45D with a bale spear on the 3PH and handle round bales just fine with no problem. The D45 can lift bales up to 2000 lb very easily. With a LX116 loader and some weight in the bucket, maybe even more. I've never tried a bale spear on the loader, but if the bale is less than 1500 lb and you have some ballast on the 3PH, I don't see a problem there either.
The maneuverability of a tractor this size makes it ideal for close-quarter work around stalls and barns in my opinion. /forums/images/graemlins/cool.gif
Jim,
they will range in the 1200 to 1500 pound range.
Unless she gets some other type of grass.
It only has to lift off a pickup flatbed and
stacked about two high. Everything else
calls for a smaller tractor but the hay part.
I did test drive a TC33 with the hydro and
Supersteer. Very nice and if if was up to
me I would probably go New Holland.
She has good suport for it and is the
closest dealer.
Pemberton Inc 416469 Hydraulic Dual Cylinder Grapple Loader Bucket (A64194)
Pemberton Inc...
2013 FREIGHTLINER M2 4X2 26FT NON CDL BOX TRUCK (A67148)
2013 FREIGHTLINER...
2001 Peterbilt 330 4,000 Gallon Water Truck (A64194)
2001 Peterbilt 330...
2017 DITCH WITCH JT20 DIRECTIONAL BORING MACHINE (A63276)
2017 DITCH WITCH...
2014 FREIGHTLINER CASCADIA CA113DC T/A 6X4 DAY CAB TRUCK TRACTOR (A67148)
2014 FREIGHTLINER...
Lesco 50Lb Push Spreader (A64557)
Lesco 50Lb Push...
