D40 temp gauge
/ D40 temp gauge #1
klm
Northwest MO
Allis D17 CIH D40, JD5310, Massimo MS50010
My D40 does not have a temperture gauge but does have a knock-out panel in the instrument panel for one. Would it be possable to add one?
/ D40 temp gauge #2
The DX40 has a temp guage. It COULD be added to the D40 if you get a sensor and guage. You may need to add wiring to make this work too.
/ D40 temp gauge
Thanks, I'll check with the parts man the next time I am there. Just don't like not having a temp gauge. Not only for telling me when it's too hot but for telling me when it's not running where it usually does. That can be a clue to a problem developing.
/ D40 temp gauge #4
I agree, I love gauges. Fun to watch and can warn me before the idiot light goes on!
Bob
/ D40 temp gauge #5
Ask your dealer if the sending element is the same for the gage and the idiot light. If it is, then all you need is an instrument panel with the gage. Perhaps it could be ordered for a DX model and installed on your tractor. I doubt that you can order less than the whole instrument cluster. I think it's a "unit" replacement. Several people have had instrument panels replaced due to fogging. In all those cases, the entire assembly was replaced.
Good luck! I love having gages. If you don't have a gage, you will never know if your tractor is running too cold (thermostat stuck open) which has happened on a lot of NH and Case compact utility tractors.
/ D40 temp gauge
Maybe should just trade it on a DX40 or 45.
/ D40 temp gauge #7
Good idea.
I wish I had a Turbo Gauge on my NH. i had one on my old SAAB that had a turbo. Always fun to see when the turbo was working.
Bob
Bob
/ D40 temp gauge #8
Ahhh Yesss! Saab turbo's, especially the 900 series, are great cars! My '85 900t 3 door (black of course, 5 speed of course) made the most wonderful whistle as the turbo kicked in, then we just flat disappeared. The boost overpressure relief control had been modded "a bit" and the car would just about fly! I had to use cable ties to keep some of the fittings from being blown out of the plenum, but it sure was fun to drive. The SPG that replaced it wasn't near as much fun, despite being the "high performance" model.
It's also pretty cool to be on a long uphill grade on a freeway running among the semi's and listen to turbo's spool up as the drivers change gears. There's just something magic about turbocharger whistle and the implications of power to come. :)
/ D40 temp gauge #9
daTeacha said:
Ahhh Yesss! Saab turbo's, especially the 900 series, are great cars! My '85 900t 3 door (black of course, 5 speed of course) made the most wonderful whistle as the turbo kicked in, then we just flat disappeared. The boost overpressure relief control had been modded "a bit" and the car would just about fly! :)
I did the same thing, even added an aftermarket air to air intercooler. On a nice cold day (15 degrees), with premium fuel the car would fly. If memory serves me right, mine was a 3 door, crank windows, and very light. I would adjust the turbo to overboost, getting lot's of pressure that SAAB probably only used on their rally cars.
Now I drive a 70HP Turbo tractor. I loved the SAAB and now I love the tractor.
Bob
2005 PETERBILT 379 CAB ONLY (A63569)
2005 PETERBILT 379...
1998 FORD F-800 4X2 S/A FLATBED/ TANKER (A59910)
1998 FORD F-800...
*Selling at Royal Auction Tampa, FL Location* (A59228)
*Selling at Royal...
2018 Unverferth 3955XL Seed Tender (A63116)
2018 Unverferth...
2006 FRAC TANK 500BBL WHEELED (A63569)
2006 FRAC TANK...
2024 John Deere 4044R Tractor (A63116)
2024 John Deere...
