bummer about the trip to the ER,hope it wasn't serious. thanks for the update to this old thread. since this post I did find a few threads on various sites saying the k66y will not work properly, but no specifics about why. I have been moving trailers, towing a sprayer around and touching up the area around the place I cant get to with the kubota and flail mower. so far the transaxle just gets warm to the touch. after about an hour. and that is about as much use as it gets in a month. so far I have been running it on 100 octane avgas I use in my race bikes and other equipment that sets around a long time between uses, the fuel never spoils. I have had to repair several carburetors that I used california pump gas in. I did add led lights to the front nerf bar and led bulbs to the head lights. I can mow after dark and see just fine. I am also building gauge pod for oil pressure, volts and oil temp. I plan on changing the trans oil to synthetic and adding a temp sensor to the drain plug once I drill and tap the transaxle. despite the bad rep this series of mower has for the weak trans I am really impressed with it so far.
