D130 - Transmission done already ?
   / D130 - Transmission done already ? #1
dirtydave
D130
Got a 4-5 year old D130 from Lowes. I wasn't expecting much, but I expected to stay moving longer than it has.
Problem is, it won't move. Put it away last fall, pulled the release-rod, to push it around inside shed.
Changed the tires in the shed, and started it up.
No forward or reverse movement, no even a sound.
Parking brake is also non-functional.
I checked the shaft that the rod attaches to, it turns when I push/pull rod back and forth.
No obvious sign of fluid leaking
The little fan on top of trns, spins when engine is running, Continues to spin , with no real sign of speed changing when forward /reverse is pushed.
What else could it be folks ? Nearest "reputable" Deere dealer is 30 miles, and they are already swamped.
   / D130 - Transmission done already ? #3
I would push and pull the rod a few times. Try it again. Do that a few more times if it doesn't work. It's gotta be related.
Steve
Steve
Yes, tried that multiple times. Moved linkage at trans by hand, with no results.
   / D130 - Transmission done already ? #5
sometimes, removing the transmission, draining the oil out, flusing the old oil with fresh, the draining that and using 100% synthetic oil will get it working again, sometimes you have to replace parts inside, the link I posted has many details! basically, you are lucky if it lasted 4-5 years, it's not designed for that, it doesn't even have a drain plug to change the oil!!..
   / D130 - Transmission done already ? #6
Was it the rear wheel? check for the axle key if it fell out and not replaced
Yes, I dropped one of them, shoved it back in though. I wish it was that simple
   / D130 - Transmission done already ? #8
That sorta kinda leads me to the belt or something in the belt drive linkage ... lack of tension or not engaging.
   / D130 - Transmission done already ? #10
It may be spinning, but is it tensioned enough to create hydraulic pressure? When one begins to slow down or not climb as well, a slipping belt is one of the causes.
2017 Jeep Patriot 4x4 SUV (A55758)
2017 Jeep Patriot...
2011 Kubota KX080-3 Midi Excavator (A53421)
2011 Kubota...
2017 Ford Explorer AWD SUV (A54815)
2017 Ford Explorer...
2005 Chevrolet Impala (A55758)
2005 Chevrolet...
2013 Ford F-150 4x4 Crew Cab Pickup Truck (A55788)
2013 Ford F-150...
(APPROX 25) UNUSED LANDHONOR PINS (A54757)
(APPROX 25) UNUSED...
