D130 - Transmission done already ?
   / D130 - Transmission done already ? #1
dirtydave
D130
Got a 4-5 year old D130 from Lowes. I wasn't expecting much, but I expected to stay moving longer than it has.
Problem is, it won't move. Put it away last fall, pulled the release-rod, to push it around inside shed.
Changed the tires in the shed, and started it up.
No forward or reverse movement, no even a sound.
Parking brake is also non-functional.
I checked the shaft that the rod attaches to, it turns when I push/pull rod back and forth.
No obvious sign of fluid leaking
The little fan on top of trns, spins when engine is running, Continues to spin , with no real sign of speed changing when forward /reverse is pushed.
What else could it be folks ? Nearest "reputable" Deere dealer is 30 miles, and they are already swamped.
   / D130 - Transmission done already ? #3
I would push and pull the rod a few times. Try it again. Do that a few more times if it doesn't work. It's gotta be related.
Steve
Steve
Yes, tried that multiple times. Moved linkage at trans by hand, with no results.
   / D130 - Transmission done already ? #5
sometimes, removing the transmission, draining the oil out, flusing the old oil with fresh, the draining that and using 100% synthetic oil will get it working again, sometimes you have to replace parts inside, the link I posted has many details! basically, you are lucky if it lasted 4-5 years, it's not designed for that, it doesn't even have a drain plug to change the oil!!..
   / D130 - Transmission done already ? #6
Was it the rear wheel? check for the axle key if it fell out and not replaced
Yes, I dropped one of them, shoved it back in though. I wish it was that simple
   / D130 - Transmission done already ? #8
That sorta kinda leads me to the belt or something in the belt drive linkage ... lack of tension or not engaging.
   / D130 - Transmission done already ? #10
It may be spinning, but is it tensioned enough to create hydraulic pressure? When one begins to slow down or not climb as well, a slipping belt is one of the causes.
2017 Ford F550 Altec Bucket Truck (A52377)
2017 Ford F550...
2007 Ford E-450 Super Duty 16ft Portable Office Truck (A55852)
2007 Ford E-450...
HANGCHA CPCD25-XW98C-RT4 STRAIGHT MAST FORKLIFT (A51406)
HANGCHA...
New JMR Skidloader Stump Bucket (A50775)
New JMR Skidloader...
Unused Delta Crash...
