Got a 4-5 year old D130 from Lowes. I wasn't expecting much, but I expected to stay moving longer than it has.
Problem is, it won't move. Put it away last fall, pulled the release-rod, to push it around inside shed.
Changed the tires in the shed, and started it up.
No forward or reverse movement, no even a sound.
Parking brake is also non-functional.
I checked the shaft that the rod attaches to, it turns when I push/pull rod back and forth.
No obvious sign of fluid leaking
The little fan on top of trns, spins when engine is running, Continues to spin , with no real sign of speed changing when forward /reverse is pushed.
What else could it be folks ? Nearest "reputable" Deere dealer is 30 miles, and they are already swamped.
