Cylinder seal repair
   / Cylinder seal repair #11
I'm repairing Woods 195 lift cylinders. All disassembled no prob. Now planning assembly. What should be used to seal threaded rod caps ? Took heat and big cheater to remove. Thinking heat was the trick. Is there a Loctite product, or will Teflon tape allow the threads to seal? I know from steam piping bare threads rarely seal, but I'm finding nothing on how to seal rod caps.
   / Cylinder seal repair #13
J_J, thanks so much. I'll get it before I put them together.
   / Cylinder seal repair #14
What is a "Rod Cap".........Rod gland?
   / Cylinder seal repair #15
Yes the threaded end of the cylinder with the rod seal.
   / Cylinder seal repair #16
........ Is there a Loctite product, or will Teflon tape allow the threads to seal?.......
There should be orings/backups to seal that gland to the barrel.......maybe they got burnt with the heat?
Pix?
   / Cylinder seal repair #17
Yes there are orings to seal the gland. The rod cap really doesn't seal, it just hold the gland in place. I put some thread sealer on them. If there is leakage between the gland and cylinder wall, it should slow it down. I installed the cylinders yesterday and cycled them. Tight as a gnats ***. Opps, the tilt cylinders leak. Should have known this will be an all year project. wdchd, love those dogs. I have a beagle mix, and he is super.
   / Cylinder seal repair #18
I had to use a few wraps of teflon tape on mine. They had o-rings but still leaked past the threads and then past the o-rings. The teflon tape on the threads solved the problem. Kind of bizarre but haven't leaked for years so I'm not going to try to reinvent the wheel.
FORREST RIVER CHEROKEE CAMPER (A52472)
FORREST RIVER...
2018 FORREST RIVER CRUISE LITE CAMPER (A52472)
2018 FORREST RIVER...
2018 KENWORTH T800 DAYCAB (INOPERABLE) (A53843)
2018 KENWORTH T800...
20357 (A55758)
20357 (A55758)
2008 New Holland B110 MFWD Loader Backhoe (A57024)
2008 New Holland...
STAR EV 36V ELECTRIC GOLF CART WITH BATTERY CHARGER (A53424)
STAR EV 36V...
