Cylinder head
   / Cylinder head #1
Jwolf223
Oglesby,TX
Ford 9n
I'm working on a 406 international diesel with a blown head gasket and the head won't come off we've tried a jack and a hoist to lift it off but it won't budge all the head bolts are removed any other help would be great
   / Cylinder head #2
There should be some prying lugs cast into the block and head where you can pry with a crowbar. Apply constant lifting pressure and then pry with bar. Maybe a few good blows with a dead blow hammer.
   / Cylinder head
We've tried that and bent a six foot pry bar hoping to get it loose
   / Cylinder head #4
Try to start it!
   / Cylinder head
If that don't do it then hopefully a 20 ton bottle jack will break it free
   / Cylinder head #6
Before you get a jack under it double check for a missed bolt i know that sounds simple but ive seen many a mechanic warp or crack a head like that.
   / Cylinder head #7
For sure double check for that missed bolt!
Also:
Could you not engage the starter and let the compression do the task 4U ?
That would exert a nice rather even pressure I should think. I have done that, agreeably on smaller engines with success.
John Deere 5090E Tractor with Loader Prep Package, 2 Rear Remotes, Warranty Until 2028 (A52748)
John Deere 5090E...
2004 International 7500 T/A Roll-Off Truck (A50323)
2004 International...
2015 Ford F-550 Chassis Truck (A50323)
2015 Ford F-550...
1262 (A50490)
1262 (A50490)
2014 Volkswagen Jetta Sedan (A50324)
2014 Volkswagen...
378936 (A51573)
378936 (A51573)
