Cylinder head
   / Cylinder head #1
Jwolf223
Oglesby,TX
Ford 9n
I'm working on a 406 international diesel with a blown head gasket and the head won't come off we've tried a jack and a hoist to lift it off but it won't budge all the head bolts are removed any other help would be great
   / Cylinder head #2
There should be some prying lugs cast into the block and head where you can pry with a crowbar. Apply constant lifting pressure and then pry with bar. Maybe a few good blows with a dead blow hammer.
   / Cylinder head
We've tried that and bent a six foot pry bar hoping to get it loose
   / Cylinder head #4
Try to start it!
   / Cylinder head
If that don't do it then hopefully a 20 ton bottle jack will break it free
   / Cylinder head #6
Before you get a jack under it double check for a missed bolt i know that sounds simple but ive seen many a mechanic warp or crack a head like that.
   / Cylinder head #7
For sure double check for that missed bolt!
Also:
Could you not engage the starter and let the compression do the task 4U ?
That would exert a nice rather even pressure I should think. I have done that, agreeably on smaller engines with success.
2001 Subaru Outback AWD SUV (A51694)
2001 Subaru...
Duetz Power Unit (A50120)
Duetz Power Unit...
2017 Nissan Titan Crew Cab Pickup Truck (A50323)
2017 Nissan Titan...
New 20ft 5/16in G70 Tie Down Chain (A50323)
New 20ft 5/16in...
NEW Wolverine 72'' Skid Steer Ripper (A53002)
NEW Wolverine 72''...
2010 PETERBILT 340 (A52472)
2010 PETERBILT 340...
