Cylinder extension
/ Cylinder extension #1
rmully
North Carolina
YM 2020
I have a cylinder that is 36" from center of hole to center of hole while closed... I am trying to figure out what will be the length when extended fully. Can I put air in the cylinder to extend it? This is all new to me and I am trying to make a log splitter. Any formulas.... The label on the cylinder was rubbed off but I know it is a Chief.
/ Cylinder extension #2
Don't use air!!!!!!!! If you can't pull it open by hand you could use your tractor. Go slow.
Thanks ... I have a come-along that I will try.
/ Cylinder extension #4
I have used air many times, but you must be prepared for it to open quickly and have the body of the cylinder secured.
/ Cylinder extension #5
May I ask what's the reason for not utilizing air to extend the cylinder? There are air operated cylinders being used.
/ Cylinder extension #6
A lot of hyd cylinders are marked with their diameter & stroke.
/ Cylinder extension #7
I have used air also alot of times, but I didn't like telling someone to use it and getting hurt.
/ Cylinder extension #8
put in vise , put a rod thru the eye, pull and twist at the same time .....
low pressure air works well , but can extend the rod quickly ...
Rhino DB150 (A57148)
2018 International DuraStar 4300 2,000 Gallon Water Truck (A59230)
2018 International...
2022 John Deere 5055E (A60462)
2022 John Deere...
Gleaner N630 Corn Head (Allis Chalmer Branded) (A61307)
Gleaner N630 Corn...
HIGH END MINI GOLF CART (A58214)
HIGH END MINI GOLF...
2016 Dodge Grand Caravan Van (A59231)
2016 Dodge Grand...
