Sep 7, 2007 / Cylinder drift #1 J jmfox Platinum Member Joined Nov 17, 2006 Messages 776 What causes a double action cylinder with no leaks to drift? Every other cylinder on the system does not drift. jmf
Sep 7, 2007 / Cylinder drift #2 kennyd Advertiser Joined Jul 6, 2003 Messages 13,845 Location Westminster, MD Tractor John Deere 3720 CAB/TLB, JD455 The fluid is bypassing the piston seals internally. It sounds like it need to be rebuilt.
Sep 8, 2007 / Cylinder drift #3 J john_bud Super Member Joined Sep 23, 2000 Messages 6,680 Yep, internal bypassing is the usual answer 99% of the time. The other 1% is a worn control spool. It is leaking, but not where you can see it. jb
Sep 8, 2007 / Cylinder drift #4 D Digdeep Gold Member Joined Mar 29, 2006 Messages 268 You may also have a seal that is nicked that is causing this. Possibly in the cylinder or in the loader valve. It should be pretty easy to fix.
Sep 8, 2007 / Cylinder drift Thread Starter #5 OP J jmfox Platinum Member Joined Nov 17, 2006 Messages 776 Thanks. If you can't see something leaking, it doesn't mean it's not leaking. On removing it I noticed it is rebuildable, so I guess the best thing to do is take it down to the cylinder rebuild shop. jmf
