Cylinder drift
/ Cylinder drift #1
jmfox
Platinum Member
What causes a double action cylinder with no leaks to drift? Every other cylinder on the system does not drift.
jmf
/ Cylinder drift #2
The fluid is bypassing the piston seals internally. It sounds like it need to be rebuilt.
/ Cylinder drift #3
Yep, internal bypassing is the usual answer 99% of the time. The other 1% is a worn control spool.
It is leaking, but not where you can see it.
jb
/ Cylinder drift #4
You may also have a seal that is nicked that is causing this. Possibly in the cylinder or in the loader valve. It should be pretty easy to fix.
/ Cylinder drift
Thanks. If you can't see something leaking, it doesn't mean it's not leaking. On removing it I noticed it is rebuildable, so I guess the best thing to do is take it down to the cylinder rebuild shop.
jmf
2006 Dodge Charger Sedan (A64557)
2006 Dodge Charger...
2013 PETERBILT 367 (A65643)
2013 PETERBILT 367...
2016 Polaris Ranger 570 (A62613)
2016 Polaris...
2013 Komatsu PC360 Excavator (A60352)
2013 Komatsu PC360...
Case 90XT Skidsteer Loader (A66285)
Case 90XT...
New/Unused Quick Attach Backhoe Attachment (A65583)
New/Unused Quick...
