Rake Cyclone Rake Anyone?
/ Cyclone Rake Anyone? #21
If the leaves are at all wet, it does get pretty heavy to dump. I try not to fill it completely if there is any moisture. They do offer the electric dump option if you want to spend a few bucks.
Storage space isn't much of an issue if you get the hanging brackets. When you fold it up and hang it very little floor space is required.
I wondered about the durability of the bag also, but after 13 years, mine is almost like new.
/ Cyclone Rake Anyone? #22
I have the larger unit & I pull it with a Scott 18hp 42" deck. My property is very sandy. I have had this unit almost 3 years now. The sand causes wear on the titanium plates inside the inpeller & shute & it also causes the fabric at the attachment point to the shute to wear, even with the rubber piece in place. To help eliminate this a I added a steal plate that is about 18 gauge to the shute & it extends into the bag to help direct the debris down. This has helped for the fabric but not the plates. CR did replace all my plates & sent me a new bag under warranty. The new plates are a heavier gauge than the originals.
The issue of not being able to tell when the bag is full that has been mentioned. I know my bag is about 3/4 full when I make a turn & the CR wants to not follow & force me to go straight. That is how I know it is time to dump. I vacumn my 2+ acres about 3 times each fall winter. I'm happy with the CR & would recommend it, Just know if you have a sandy yard that also tends to wear your mower blades down to unusable blades there is also going to be wear on the CR components.
1990 Bayliner 19ft Trophy Center Console Boat w/ S/A 20ft Boat Trailer (A59231)
1990 Bayliner 19ft...
2008 Mercury Milan Sedan (A59231)
2008 Mercury Milan...
Wacker Neuson VP1550AW Vibratory Plate Compactor (A59228)
Wacker Neuson...
2005 Komatsu HM-400 (A60462)
2005 Komatsu...
500BBL SKIDDED FRAC TANK (A60736)
500BBL SKIDDED...
2014 MAGNUM PRODUCTS LIGHT TOWER COMBO (A58216)
2014 MAGNUM...
