CX300 on JD4100
/ CX300 on JD4100 #1
QuasarZ
Western WI
Previous Branson 2400H. Looking for new
I am looking to buy a tractor and ran across a JD 4100 that the owner says he put on a new loader. Looking at the picture it reads cx300. Is this loader compatible with the 4100? I can't find any info on the web about compatible models. On another note (this may need to be in buying forum) but is 12,900 a good price for this tractor with that loader, 4 new turf tires with tubes, and 60" deck? Doesn't list a year, but it has 110 hours.
Appreciate the help.
/ CX300 on JD4100 #2
If he modified the loader to fit as long as it was done properly I don't see the problem. The hours seem extremely low. Check tractor data dot com for information on the tractor like year range. A dealer will give you a build date with serial number. Good luck.
/ CX300 on JD4100 #3
That's definitely a custom fit, the 410 and then later the 200cx loaders did fit with available mountings from JD. The lift capacity of the 300 loader is about twice that of what was meant for the 4100 so I'd be concerned about front axle wear, I hope he used some real rear ballast!
Check machinefinder and tractorhouse for retail pricing.
/ CX300 on JD4100 #4
Ask the owner which loader it is. The photo looks like 300cx but it's hard to tell. JD sells the brackets for the 200cx or H130 loader to fit a 4100 but the 300cx is a bit larger so who knows. If that were closer I'd be looking at it myself. Looks like a very clean tractor unlike several I've seen in my recent searches.
/ CX300 on JD4100
It is a 200cx loader. He isn't sure of the year and he's only had it for about a year. I am leery.
1999 Playbuoy Pontoon and Boat Trailer (A62613)
1999 Playbuoy...
1995 20 Ton Equipment Trailer (A65563)
1995 20 Ton...
John Deere 24in Backhoe Bucket (A65640)
John Deere 24in...
New/Unused Mini Skid Steer Mounting Plate (A65583)
New/Unused Mini...
2022 CATERPILLAR D8T HIGH TRACK CRAWLER DOZER (A65053)
2022 CATERPILLAR...
2019 KENWORTH T880 (A65643)
2019 KENWORTH T880...
