Cutting PTO Shaft
/ Cutting PTO Shaft #1
theboman
Grayson, KY
Kubota B7500 HST
Okay what's the best way to cut down a PTO shaft? Making the shaft on my tiller 3-4+ shorter will make it a lot eaiser to hookup.
/ Cutting PTO Shaft #2
King Kutter has illustrated instructions in their Adobe acrobat manual for their rotary cutters. Find it at <A target="_blank" HREF=http://www.kingkutter.com/>http://www.kingkutter.com/</A>
Chris
/ Cutting PTO Shaft #3
The last one that I had done, I took to a machine shop. They put it on a lathe, cut the yoke off one end, cut the shaft, welded the yoke back on and balanced it. $20. Been a few years ago though.
/ Cutting PTO Shaft #4
If I were to do it I would use a sawzall with a metal cutting blade. Then debur the ends and put it back together.
/ Cutting PTO Shaft #5
I agree with Von,use a sawzall, unless you have access to either a chop saw or a metal cutting band saw (floor model, not portable) as it is easier to get a straight flush cut. You can even use a hacksaw if you don't have access to power tools, but its a lot more work.
/ Cutting PTO Shaft #7
EdKing,
I did use a hack saw after I discovered that my son had used all the blades for the Makita recip saw. Did OK, would rather have done it with power though /w3tcompact/icons/smile.gif .
/ Cutting PTO Shaft #8
Like the others (except for the power tool challenged), I used a Sawzall. One trick I learned from an old timer was to use a dowel or skinny piece of scrap wood as a story stick to get the length right the first time.
Pete
/ Cutting PTO Shaft #9
Yeah, those recip saws are nice. I have a Porter Cable tiger saw. What a work horse. I recomended the other saws as I some times have trouble drifting when I am cutting with the recip. My wife even bought me a cordless Black & Decker recip for Christmas, its nice for small jobs where there is no power, but doesn't hold a candle to the Porter Cable.
/ Cutting PTO Shaft
Story stick? Explain please.
/ Cutting PTO Shaft #11
I just cut the shaft for my chipper with my neighbor's power bandsaw. It had a base that allowed it to operate like a chop saw so it gave a nice, straight cut. He recommended not using a chop saw with a metal blade as it tends to burn through the metal and leaves more to de-burr.
I've only seen this one shaft, so I don't know if they are all the same. One end had a square, solid shaft and the other end was square tubing that fit over it. I wouldn't want to try cutting the solid end with a hack-saw, but it could be done. I couldn't figure out how to remove the safety cover from my shaft without destroying it. Because of this, we were only able to clamp on the "waste" end. This motivated us to get the length right the first time.
For measuring, a service person at my dealer recommended mounting the implement and setting the height with the shafts horizontally aligned. This is the shortest length of the shaft. He recommended adjusting the length so that you got the maximum overelap with only 1" of spare. He also suggested cutting the two ends to equal lengths.
I used a tape measure to find the length from the detent ring on the PTO to the point on the chipper shaft where the outside edge of the yoke seats. I then laid both pieces of the shaft side by side and adjusted the total length to match. After marking the length of each end, I used a small saw to trim the plastic guard back and the used the power band saw to trim. Be careful with the burrs, they are very sharp (and I should know better).
After reassembly, I cycled the 3 pt hitch through the entire vertical range to ensure there was no binding.
/ Cutting PTO Shaft #12
I've only had to shorten one myself, and I did take an equal amount from each end, as the manual suggested. And at that time, all I had to do it with was a manual hacksaw, and it was much easier than I expected.
/ Cutting PTO Shaft #13
I had to do this on the snowblower when I added an ORC to the pto (old tractor, no live pto).
The front part of the main shaft, that receives the sliding square part coming back from the front U-joint, is really just a short section that is welded to the long tubular part. A certain length of it is of reduced diameter and slides inside the main part of the shaft. My neighbour the welder had seen this before and cut through right at the existing weld, whereupon the front section came out of the outer. Then we just cut down the outer one, and reinserted the inner section and welded it back together.
Don't know how common this is but it was pretty nifty. We got the reassembled shaft pretty straight.
Jim
/ Cutting PTO Shaft
I used a hacksaw. I wanted to use a sawzall but since I don't have one, and this is the second time I could have used one in the past 3 years I wasn't gonna buy a tool that wasn't gonna get used. Did I tell you that I used a hacksaw. Next time I gotta do this I will but a sawzall! It wasn't hard but it wasn't fun or fast.
/ Cutting PTO Shaft #15
REAL men just bite 'em off! /w3tcompact/icons/king.gif
I used a hacksaw. /w3tcompact/icons/blush.gif
Chuck
/ Cutting PTO Shaft #17
I've never cut one down...how thick is the metal on the shaft (I know they're tubular...)
Could this be done with a pipe cutter? That would keep the cut nice n' square to the longitudinal axis of shaft.
Just curious...
/ Cutting PTO Shaft #18
Mine wasn't tubular. The outer plastic cover is tubular but inside that is a piece of square tubing connected to one end that slips over a solid square stock connected to the other end. The squares are about an inch. A piper cutter wouldn't work very well.
/ Cutting PTO Shaft #19
I have 3 different types of PTO shafts at home and none are round so a pipe cutter wouldn't work. I have two Comer's that are kind of like a triangle with bowed sides (if there's a proper geometric name for this shape, I'm unaware). I have an old, unshielded one (that I don't use anymore) that is just a square tube and a solid square shaft. The last is the weirdest - it is round but has to "ears" 180 degrees from one another.
The metal can't be more than an 1/8" thick on mine. As for it being square, I don't think that being out of square would make much difference.
/ Cutting PTO Shaft #20
Roy, they're tubular, but not round, so I don't think a pipe cutter would work. If I had one to do not, I'd just use my little reciprocating air saw; much smaller and lighter than a sawzall, but of course an air compressor is required.
2020 Peterbilt 367 Weldco Hydra-Lift WHL45TC100 45 Ton Tri Axle Telescopic Crane Truck (A55973)
2020 Peterbilt 367...
ASSET DESCRIPTIONS & CONDITION (A59906)
ASSET DESCRIPTIONS...
DEUTZ MARATHON 60KW GENERATOR (A58214)
DEUTZ MARATHON...
2020 PETERBILT 567 (A60736)
2020 PETERBILT 567...
2017 Freightliner M2 106 AWD Terex Hi-Ranger 5TC55 55ft. Insulated Material Handling Bucket Truck (A60460)
2017 Freightliner...
John Deere XUV825E (A61307)
John Deere XUV825E...
