cutting out a hill
/ cutting out a hill #1
GlenncN
Bernice
N/A
I'm planning on cutting out approximately 200x200 out of a hill to build a house. Now the house will not be near this big but I want to have plenty of room around it. But I want to cut this out leaving a wall in the back. I know I'll have to build a retaining wall but that is no problem.
Now I don't have the exact measurement or figures but guessing I'm saying I'll have to dig down about 8' in the back leveled out to 0' in the front. Some of the dirt that will come from this will be used to fill in a ditch which will have a 12" culvert in for the driveway. Some will be used to filling washouts on my land.
My question is will I be able to do this using a track loader?
/ cutting out a hill #2
Given enough time and money you can do anything you set your mind to. Just remember, moving dirt isn't cheap, especially on a big project with a small machine. If your not in a hurry, I dont see problem with it. My question would be, what happens if your track loader breaks down?
/ cutting out a hill #3
Very true. You could dig it out with a spoon if you adjust the timeframe far enough out.
I'm presuming that you would want to use a track loader because that's what you own. Why not consider renting a piece of heavy equipment over a short duration to do at least the bulk of the work? Digging 8' of dirt, there's a fairly good chance you're going to run into something that's bigger than what that track loader can handle.
What about hiring someone to do it? Have you priced that? Maybe you know someone that would barter the work (or use of a machine) with you to keep actual dollars off of the table.
I forgot to add that the area I'm planning to this in is in the middle of a field. There are no trees which means no roots. We used to grow watermelons and peas there. Rocks are my main concern. The first few feet is sand then it turns to red clay. There may be some iron ore.
I'm in no hurry to do this and the reason I asked about the track loader or crawler is because I have access to a 755K.
/ cutting out a hill #5
A track loader can move a lot of dirt fast. Go for it!
/ cutting out a hill #6
I use all cat equipment so I'm not up to date on other model sizes but the size cat I use is a 963. Will dig through rock and extract boulders the size of cars with ease. Hopefully you don't run into a situation where you hit a rock shelf and blasting is required.
/ cutting out a hill #8
How big is the bucket on that crawler?? deere list ~3 yards??
I may be wrong but I dont think you realize just how much dirt their is. 200x200 going from 8-0 is about 6000 yards of dirt. Digging isnt the biggest issue. But moving and doing something with 6000 yards of dirt is. Crawlers arent exactally fast at transporting the dirt any distance at all.
So...You are looking at 2000 scoops of dirt. With transportation time, lets say you average 2 minutes per scoop, thats 4000 minutes. (67 hours.) Working 10 hours a day, thats a full week.
Now, not trying to discourage you, just making you aware that this is quite an undertaking. How soon does this need done? How many hours a week can you devote to it? You can do the math and decide if it is something you want to do or not. It can most certainly be done. But can it be done in a timely manner you are satisfied with?
/ cutting out a hill #9
Nobody has mentioned that it should be fun!
If you are just pushing off to the side it won't be too bad, if scoop and travel, it will take a lot of time.
/ cutting out a hill #10
/ cutting out a hill #11
6000 yards of compacted earth in place, but it will be 7000 or more of loose spoil once extracted.
/ cutting out a hill #12
The math here is correct. Now add in a current bid price for excavation of $8.00 per cubic yard and your talking $48,000 dollars to have it done by people with the right equipment in hand. Do you really need to level out nine tenths of an acre?
/ cutting out a hill #13
If the price is $50k I'd recommend taking a couple of weeks off and make it happen. That's going to burn a lot of fuel! Have fun and drive in straight lines to lessen the chances of track failure.
I spent 50 hours digging out and rebuilding a hill with my 1026r it was about 40 yards of material and the pile was far away on a hillside. I've got a nice yard and wall there now!
/ cutting out a hill #14
/ cutting out a hill #15
Where are you getting them kind of prices at??
Around me, its about $1.50 per yard. That would make that a ~$10k job. Maybe a tad more but depends on the lay and how far the dirt has to be moved or handled. And if trucked out, that would be more.
/ cutting out a hill #16
That was a current winning bid on a local highway project. Big boys playing with big toys for sure but nobody else underbid them. With fuel and machinery prices what they are plus the wages for the operators and truck drivers (Davis Bacon rates) it would be very hard to get to $1.50 today and a do it yourself project using old and undersized equipment will be hard pressed to do better then what those in the business can deliver.
/ cutting out a hill #17
Yea, I can see that now on a highway project. Probabally handling the dirt several times, load, haul, unload, spread. Plus compaction in prep for road base, etc.
But just digging into a hillside (or a pond like I just had done) seems a bit excessive. My pond to my nearest estimation (1/3 acre) required about 2500 yards of dirt dug out and spread. Got 'er done for $3500. And most quotes were under 5k.
At $8 per yard, that would have made my little 1/3 acre pond cost 20 grand:confused2: I dont think anybody would get work around here with prices like that
/ cutting out a hill #18
It is a funny business with few rules. Sometimes you see contractors bidding jobs at a known loss just to get the work and make it through to better times. By known loss I mean they are spending some of the equity they have in their equipment and truck fleet to keep all their help working and available if something more profitable comes up. You can add new equipment anytime you have the work but you can't pull skilled workmen back after you have let them go as all the good ones will find a different job that pays as well with less uncertainty.
As to doing it for $1.50 a CY you would have to show me what machine depreciated over 10,000 hours and using it's known rate of fuel consumption per hour at $4.00/ gallon and up plus the operators wages and taxes (Forget benefits) divided into it's yards per hour productivity comes out to $1.50/cy . They used to be able to do that when fuel and new machinery was cheaper but not anymore.
/ cutting out a hill #19
the areas were you move the dirt is going to be a problem as in you will most likely want to compact the dirt as you bring dirt into the areas to fill in the areas. so you do not end up with a ugly mess later on down the road.
if you had access to a couple dump trucks. that 1 person could load at the house area, and having dump trucks going back and forth between dump sites, and then another person in a large tractor / compaction tractor and another person in a dozer or like to push dirt down into areas. you would really get things done quickly. of course having a crew that has it together makes life easier. and if you did good prep work before hand to reduce the crew time could save you a good amount of time and cash as well.
for me with the ford 555c TLB. driving 1/2 mile to 1 mile trip between digging area to spot were i am putting dirt. that travel time alone eats up entire day vs, actual time digging and compacting dirt things.
just having a good say 15 ton dump truck. would really help move dirt around faster. and take less toll on you and machinery. you could always buy a used dump truck use it / fix things as needed. and then sale the dump truck. *shrugs* "loader" means it would be good at "loading dirt into a dump truck".
/ cutting out a hill #20
I dont know if I can break it down for you or not, but it was only two excavators and one dozer that did my pond in 20 hours. AND only two operators. IE: the dozer sat most of the time. And none of the equip was big. Just a PC120 komatsu, a cat Midi ex, and a komatsu d21 or d26?? dozer.
Again, all small equip. And you are saying that two guys would be justified charging 10k per day??? (or 5k each person) for a days work?????
2025 Precisions Provencal 22ft. 5th wheel Mobile Office/ Showroom Trailer (A64556)
2025 Precisions...
2003 PETERBILT 330 DAY CAB (A67714)
2003 PETERBILT 330...
2020 ISUZU NPR 16FT BOX TRUCK (A59914)
2020 ISUZU NPR...
2004 John Deere 8320 (A63688)
2004 John Deere...
2026 KH72 72in Hydraulic 4-Way Clamshell Bucket Skid Steer Attachment (A66734)
2026 KH72 72in...
2015 FREIGHTLINER CORONADO 122 SD (A67714)
2015 FREIGHTLINER...
