Cutting 3/8 plate?
/ Cutting 3/8 plate? #11
I used to cut all my steel with a circular saw...well..several saws.
Now,I use my 7 inch grinder for much work that needs a straight edge.Finding and paying for good thin cutting blades can be a hassle,but I use the worn down ones in my 4 1/2 grinder.
44 years old and finally got a torch set!!
/ Cutting 3/8 plate? #12
</font><font color="blue" class="small">( you will be hours and hours trying to grind through it. If you want to use a 4 1/2" grinder you better get a few cases of disks and set aside a few months. /forums/images/graemlins/grin.gif )</font>
I'm with Dargo here, but I'd add another grinder to the list. That much grinding will either burn it out, or age it enough to need replacing anyway.
This could cost you allot of money in materials and when your done, it's gonna be a lousy looking cut.
If apperances aren't important, call a welder with a torch and pay him to cut it for you on site. I'd bet what he'd charge you will be close to what you'll pay in blades and a new grinder.
When I buy really thick material, I pay the extra charges to have them cut it to sizes I can work with. To me, it's cheaper and safer.
Eddie
/ Cutting 3/8 plate? #13
MrJimi,
Are you talking about the Makita 7 1/4 metal cutting saw? If you are they work great. I bought a Milwaukee for my father last year for father's day. He has cut 5/8" and 3/4" thick steel with no problem. I picked up some extra steel he had laying around a couple of weeks ago to start on some pallet forks. He sent the saw with me, since he wasn't using it for any projects right now. I am really impressed after using it. It is best to clamp down what you are cutting if it is not real heavy. There are almost no sparks, since they are kept inside the blade/ chip guard. There are cutouts to follow your marks on the steel. It is very easy to cut straight and stop where needed. I see Harbor Freight now sells one for $99.99 and so does Northern. Do a search on Amazon for metal cutting circular saws and you should have most of them pull up. I imagine the HB or Northern do not have as much power as this Milwaukee, but for the price would be nice to have around. The welding shops around here also carry them as do the Snap On man. I will attach a few pictures of some 1/4" I was cutting for a couple of brackets. The side (around 44") was cut and the notch. The 44" cut took approx 30 sec. Not much different than say cutting plywood with a circular saw. I have also cut quite a bit with a sawzall before and can be done nicely with some practice. You need to angle the saw back and use the correct teeth per inch for the steel you are using. You will still a fair amount of blades over time that could be put toward one of these metal cutting saws. Jigsaws are way too slow. If you are talking about just putting a metal cutting blade (like a chop saw) in a circular saw, it does not work great, like everyone mentioned. Lots of sparks and slow. You will also probably melt your blade guard if it is not metal.
Good luck,
Russ
/ Cutting 3/8 plate? #14
Next
/ Cutting 3/8 plate? #15
Third
/ Cutting 3/8 plate? #16
Fourth
/ Cutting 3/8 plate? #17
Fifth
/ Cutting 3/8 plate? #18
MrJimi please have your supplier shear these plates out for you. It will be pennies on the dollars it will cost you in time even more time than money. Ob1 /forums/images/graemlins/wink.gif
/ Cutting 3/8 plate? #19
Last one.
I am calling metal supplier in morning, The cost for cutting will be right up there and the saw that 1savoy speaks of is like $359. and after the cutting, I still have saw /forums/images/graemlins/smile.gif for next projects. I like the saw purchase idea for the great tool.
I will find out for sure in morning, the 4' X 8' X 3/8' plates are only $220. each and weigh 490# each
Thanks
Jim /forums/images/graemlins/smile.gif
Spreader Attachment (A56859)
Spreader...
Giyi GY-QSJ Mini QA Broom Sweeper (A60463)
Giyi GY-QSJ Mini...
2008 TCE MANUFACTURING 20GN GOOSENECK GEN TRAILER (A58214)
2008 TCE...
KJ K0720 7'x20' Metal Gate (Deep) (A60463)
KJ K0720 7'x20'...
2003 STERLING LT9500 SERIES DAYCAB (A58214)
2003 STERLING...
2023 Unverferth 3PT 10 FT Perfecta Field Cultivator (A61307)
2023 Unverferth...
