cuttin grass
/ cuttin grass #21
firemanpat2910 said:
We have scattered the dust a few times but cut grass????
No rain in 2 months,none on the forecast. Load that hay up and bring it south,I would bet you will make a killing.
Only 2" of rain since the middle of Feb here and doesn't look like anything is going to change that anytime soon. The Peanut and Cotton farmers are really hurting and are only planting those fields which have irrigation.
/ cuttin grass #22
I'm in north central fl.. havn't had rain in a while either. Forecast is for possible showers for the next 4 days.. including yesterday.. All it ever does is get dark.. no rain.. just lots of smoke from south ga and lots of florida burning...
Gotta get some rain soon or I'm gonna loose my pasture entirely..
soundguy
/ cuttin grass
i dont suppose Andrea is going to help you out much huh....
/ cuttin grass #24
I need rain way over here where the red x is. I dont think this storm is gonna help. Maybe next time.
/ cuttin grass
For the first time sence ive owned the tractor i took the trouble to clean the bottom of the deck and sharpen blades this past weekend.... :eek:
needed to use the 4' bar from my Hi-lift jack as a cheeter to get the bolts off. (although im not shure i got them that tight when i put htem back on :confused: )
the blades had ben sharpened one other time, the blades on the right side (discharge side) were a lot worse than the left side....
and there was a noticable diffrance in tractor load, cut aparance, clipping size with the sharp(ish) blades.
how often do you sharpen your finsh mower blades.... im thinking of touching them up twice a season... (once at the begining and once toward the middle)
Rolling Cart (A65640)
Freightliner Tender Truck - Adams Tender (A63689)
Freightliner...
2012 PREMIER 4NNT PORTABLE PUMP (A63276)
2012 PREMIER 4NNT...
2024 SILVERBACK 53CH3A TRI/A CAR TRAILER (A59914)
2024 SILVERBACK...
Hedge Posts (A65640)
2019 PITTS CONTENDER LD35-22DC RGN LOWBOY TRL (A64277)
2019 PITTS...
