Cutter deck break
/ Cutter deck break #1
weebs1234
John Deere L120
Hi All,
All of a sudden the cutter break has engaged and won't release. If I try and start the blades it won't engage or more specific it engages but the break prevents them from spinning and starts to smoke.
I can't seem to find a reason for the break to be active. Any insight would be great or things to check.
Cheers
/ Cutter deck break #2
Is there a brake stop or do you have a electromagnet clutch that is acting up?
/ Cutter deck break #3
Sounds like some linkage came loose. Part of the blade engagement process should release the brake also. I suspect the lever(rod) that releases the brake broke or came off one end.
Bainbridge,Georgia (A65640)
Bainbridge,Georgia...
CAT 963D 4-in-1 Bucket (A68134)
CAT 963D 4-in-1...
Unused 2020 Kodiak 4AP Towable Aerator Tractor Attachment (A66734)
Unused 2020 Kodiak...
PALLET OF FUEL TANK AND TOOLBOXES (A68842)
PALLET OF FUEL...
2005 Freightliner FLD120 Ambulance (A66736)
2005 Freightliner...
STIHL FS80R POLE SAW (A64276)
STIHL FS80R POLE...
