cutter bar attach procedure?
/ cutter bar attach procedure? #1
ricky1
Southeast Ohio
Mahindra 5500,8n Ford
Anyone ever attached a Massey Ferg cutter bar to a 5500? I had it on an old ford and need to use this cutter. The bar had a flat bar connection on right side to control sway and lift, was wondering if anyone has any info or had the same idea? any forseeable problems I should be aware of? :confused:thanks!
/ cutter bar attach procedure? #2
Don't use that sway bar, as your 5500 already has sway links on your 3PH already, just adjust them to the amount of sway you want.
Thanks! also the lift pins were not long enough to clear the bars. changed those and made adjustments and have cut over 2/3 of field with no problem. Thanks again for the info!:D
2000 PETERBILT 379(INOPERABLE) (A67714)
2000 PETERBILT...
2018 BRADLEY MACHINE MINI VAC TRAILER (INOPERABLE) (A67714)
2018 BRADLEY...
2004 Johnson 40hp 4-Stroke Outboard Boat Motor (A66738)
2004 Johnson 40hp...
2023 Caterpillar 259D3 Compact Track Loader Skid Steer (A68183)
2023 Caterpillar...
Vibratory Plate Compactor (A64553)
Vibratory Plate...
CAT D5N Straight Blade / C-Frame (A68134)
CAT D5N Straight...
