cutter bar attach procedure?
/ cutter bar attach procedure? #1
ricky1
Southeast Ohio
Mahindra 5500,8n Ford
Anyone ever attached a Massey Ferg cutter bar to a 5500? I had it on an old ford and need to use this cutter. The bar had a flat bar connection on right side to control sway and lift, was wondering if anyone has any info or had the same idea? any forseeable problems I should be aware of? :confused:thanks!
/ cutter bar attach procedure? #2
Don't use that sway bar, as your 5500 already has sway links on your 3PH already, just adjust them to the amount of sway you want.
Thanks! also the lift pins were not long enough to clear the bars. changed those and made adjustments and have cut over 2/3 of field with no problem. Thanks again for the info!:D
2022 Peterbilt 567 T/A Wet Kit Day Cab Truck Tractor (A64556)
2022 Peterbilt 567...
2022 JOHN DEERE 17G EXCAVATOR (A63276)
2022 JOHN DEERE...
2026 DEVELON DX27Z-7-US30 EXCAVATOR (A64279)
2026 DEVELON...
2014 Ram 2500 4x4 Crew Cab Pickup Truck (A64194)
2014 Ram 2500 4x4...
New/Unused Outdoor Propane Patio Heater (A65583)
New/Unused Outdoor...
JCB 3TS-8T TELESKID (A65053)
JCB 3TS-8T...
