Planters CUTs with 1 or 2 row Corn/Bean planters???
   / CUTs with 1 or 2 row Corn/Bean planters??? #11
</font><font color="blue" class="small">( so when I start my run down ROW #2, why won't those cultivators tear up the seeds in ROW #1?
)</font>
The area that the cultivator tines clear will be the area between your rows.
   / CUTs with 1 or 2 row Corn/Bean planters??? #12
Here is a link to my homebuilt/modified planter for use with my CUT. I just finished it last night.
Planter
   / CUTs with 1 or 2 row Corn/Bean planters??? #14
I planted 87 acres of corn last year with a JD 7000 4 row wide corn planter, granular sidedress fertilizer, with my NH 1720 tractor. As it was a fine dry spring, worked better than using my big 7700 Ford. My 1720 is ~27 hp.
(Why? I hate planting with a cab on the tractor, & my 30-70 hp tractors are old gassers with weak hydraulics, couldn't lift the planter full of seed & fertilizer. Tried the 1720, and had a great time. Straightest rows I've planted in years with no glass in my way.)
You should only need about 5-7 hp per row on a cornplanter.
--->Paul
   / CUTs with 1 or 2 row Corn/Bean planters??? #15
Paul,
I hear you. When we went to a 4 row planter, we used an old Farmall/IH 350 because it had the better hydraulics. I don't remember, but I think it was around 30 HP.
But I do have to wonder about your 5 -7 hp per row statement. That may be true for an Ag tractor, but these CUTs are a lot lighter. I don't know where your 1720 falls, but I suspect it's not a CUT. That weight (not to mention the tires and transmission) contributes to pulling power every bit as much as the engine.
That hp/row ratio might need to be modified for a CUT.
   / CUTs with 1 or 2 row Corn/Bean planters??? #16
I believe my 1720 is about like a 33 Boomer, which is about the tractor (30 maybe?) listed originally if I can remember right...... But I do have a standard tranny, and I would not rely on my combination to work in difficult planting conditions. /forums/images/graemlins/smile.gif
Without a heavy fertilizer load & openers, a planter really is a pretty light pull tho. Only a simple disk furrow for each row, and powering a few easy turning press wheels & seed meters. You need to drive slow too - one of the biggest reasons I had a record corn yield last year - I finally drove slow enough to have ideal plant spacing! Low power gave me an extra $2000 last year.
I'm not so sure about the scratchers on that one planter pictured tho - don't get the point of that, I think those would be tossed in the corner of the shed in short order! /forums/images/graemlins/smile.gif
--->Paul
   / CUTs with 1 or 2 row Corn/Bean planters??? #17
Paul,
You make a good point -- the light loads Bob will be carrying for fertilizer and seed will negate any issues of tractor weight. He certainly has both the power and traction for a 2 row planter.
UNUSED JCT 72" HYD 4N1 BUCKET (A52706)
UNUSED JCT 72" HYD...
2014 Freightliner 105' Bucket Truck (A56436)
2014 Freightliner...
Koyker Loader DoubleTine Bale Spear - Versatile for Round and Square Bales (A56436)
Koyker Loader...
New Holland Workmaster 255 Tractor (A57453)
New Holland...
(1) HD 20ft Free Standing Corral Panel (A57453)
(1) HD 20ft Free...
40ft High Cube Shipping Container (A57453)
40ft High Cube...
