CUT to Remove Berry Bushes
/ CUT to Remove Berry Bushes #1
BoneheadNW
Washington
Kubota B7610
Can anyone give me some advice on the best implement(s) to remove berry bushes? Anyone who lives in the pacific northwest knows that blackberry, salmonberry, etc. berry bushes can be a real bugger to remove as they grow back every spring unless you take out the root system. I know that an excavator with an "opposable thumb" type of bucket can be used remove berry bushes.
Also, are the thorns on berry bushes a threat to CUT tires?
Bonehead
/ CUT to Remove Berry Bushes #2
The easiest way is a herd of goats, they'll eat them down to the ground and every time a new leaf shows, well you get the drift /forums/images/graemlins/grin.gif.
I'm in the process of doing the same thing. The salmonberries aren't so bad. I just put a chain around the bas with loop in it and yard them out. Gets 90% of the roots.
Blackberries are a little tougher to try and get to the base because of all the thorns. Try a little 2-4-D (Crossbow, but there are cheaper brands) and once they are dead, just drop your bucket and drivve in. The herbicide doesn't affect the evergreens or grasses but will flat do a number on berries, alders, and especially thistle. You can get it at any Cenex or other ag store.
Of course a small excavator will absolutely do the trick but I don't have one of those in my inventory /forums/images/graemlins/frown.gif. The thorns haven't done anything to my tires yet, they're to small to hurt my R-4's
Good luck.
/ CUT to Remove Berry Bushes #3
The really nice thing about using my tractor to rip out blackberrys is that it does not care about the stickers whereas we humans get mutilated if we look at them crosseyed. I have yet to have a berry thorn get into a tire and do any damage. As far as controling them, I use my toothbar, rip as much of the suckers out as I can and the following year will use a brush killer as need on the much reduced in size guys that pop up.
/ CUT to Remove Berry Bushes #4
As for 2, 4-D or other herbicide (round-up), they often work well on brambles in the fall when the plant draws "energy" from the old canes back to the crown.
/ CUT to Remove Berry Bushes #5
<font color="blue"> As for 2, 4-D or other herbicide (round-up) </font>
If I wanted to do a selective extermination, I would not use round-up. I save that for the gravel drive. CrossBow only works on the broad leaf plants like berries and alders. It's used by the timber industry (or was, don't know current EPA rules) to spray clear cut areas and reduce the broad leafs that would grow faster than the firs.
/ CUT to Remove Berry Bushes #6
If I don't have my excavator on the job, I usually knock them down with the front bucket on my TC40. Once I knock them down, I lower the scarifiers on my box blade and drag the scarifiers through the ground to pull up the vines. The evergreen and himalayan (sp?) vines come out really easy, but watch out for the older canes. They are pretty tough and very capable of doing damage to a tractor. Usually I just pile the vines and burn or throw a bunch of extra dirt on them and let them compost. By the time I'm done, everything is pretty clean and just needs a little hand work.
/ CUT to Remove Berry Bushes #7
You guys in the NW kill me. I am thinking of planting blackberries....you guys are ripping them out. I have a BIL who lives in Oregon. When my wife went to visit him....she went crazy picking blackberries. She ended up making a ton of blackberry coblers for her brother's family. She said the local garden shops were selling blackberry killer. One man's junk... another man's treasure.
/ CUT to Remove Berry Bushes #8
I removed mountains of blackberries from a lot we own. They came out very easily with my toothbar. I just pushed them all into a pile in the center of the lot and burned them. During the process I did some light regrading, using the toothbar to get the roots up. After that I drug it with a log and section of wire link fence to smooth it up. I planted grass and the neighbor was so happy about it, he has been mowing the lawn ever since /forums/images/graemlins/laugh.gif.
Greg
/ CUT to Remove Berry Bushes #9
<font color="blue"> You guys in the NW kill me. I am thinking of planting blackberries </font>
Out here, they'll swallow your house before you can blink...are you sure you want to plant them... /forums/images/graemlins/confused.gif
/ CUT to Remove Berry Bushes #10
/ CUT to Remove Berry Bushes #12
'das what I'm talkin' 'bout...I'll bet those are only a couple years old.
I actually did use goats a few years back to eliminate a proble similar to that, albiet not quite that tall. If you put wooden stakes around the perimeter at 2' centers and chain a tire to goats, they can't get out. The tire keeps the grass down and the goats love berry bushes. We had a white pigmy goat that had a purple mouth during berry season... /forums/images/graemlins/grin.gif
California- Those are awesome pictures! Hope you were wearing your vinyl suit with face protection. A friend of mine at my station taught me a trick in using an old set of bunker gear (firefighter turnout coat and pants) to walk right into thick berry brambles. It works but it can get quite warm!
Bonehead
/ CUT to Remove Berry Bushes #14
</font><font color="blue" class="small">( A friend of mine at my station taught me a trick in using an old set of bunker gear (firefighter turnout coat and pants) to walk right into thick berry brambles. -BoneheadNW)</font>
I could have used a coat like that. My protective gear was just a leather cowboy hat and my eyeglasses. My t-shirt got a couple of snags but I wasn't as scratched up as I expected. Mainly I avoided getting snagged by moving dead slow.
The second picture was after I shut off the tractor and used the hand pruners to clear some space so I could climb off. I had been pretty bound up when I stopped - moving forward was pulling canes down on me and backing up or lowering the bucket just made it worse.
/ CUT to Remove Berry Bushes #16
<font color="blue"> You guys in the NW kill me. I am thinking of planting blackberries....you guys are ripping them out. </font>
We don't just have "blackberries" in the NW. We have HIMALAYAN BLACKBERRIES. These are extremely invasive, non-native, and BIG. The canes get to be about as big around as my wrist, and 20 to 30 feet long. The thorns are up to a half inch long, and can pierce right through leather gloves. Sometimes they grow 20 or 30 feet up a tree, and then send down a curtain of vines that catch you as you are out mowing. If you park a vehicle or implement near the edge of the woods, it can be completely covered with vines in less than a season. The berries make OK pie or jam, but are best as jelly because they have a high seed/pulp ratio. Not as good as regular native blackberries.
I borrowed my grandpa's Kubota L345DT, and had great success attacking them with the FEL and a brush hog. Most of the patches that remain are on slopes too great for most CUTs, so I am using the brushcutter. It's a lot of work, even though I have a big Shindaiwa cutter with a 10" blade. And the stinging nettles hiding in the brush don't help either.
I recommend the FEL, a brush hog, and of course a chipper/shredder (not just a chipper) for getting rid of the remains. I have some neighbors who say the best is to cut them in the fall, and spray them at that time. I have other neighbors who had pretty good success by cutting, and then covering the ground with a tarp for a year.
Oh, and I spent a summer in South America, visiting the Amazon jungle, and there was NOTHING as dense and treachorous as blackberries in the NW!
/ CUT to Remove Berry Bushes #17
<font color="blue"> Most of the patches that remain are on slopes too great for most CUTs, so I am using the brushcutter. </font>
I am dead serious about the goat thing. and they could care less about slope. Some of the best "rock crawlers" around. You could probably find someone in the area that would be willing to pasture several goats at your place and it wouldn't be 1/10th the work to clear the brambles...just some temp fencing. I used them when I lived in Carnation and they did way better than me with a blade on a weed whacker.
PM me if you think this might work and I'd bet the lovely Mrs. could put in touch with a goat rancher...I think she got ours in Snohomish.
/ CUT to Remove Berry Bushes #18
Hmmmm. Not sure we need more animals around - the big dog, two cats, two goldfish and pet chicken are about all the kids can handle right now! So, after the goats eat the berries, what do you feed them?
/ CUT to Remove Berry Bushes #19
So bonehead, do you live on Bainbridge Island? We used to run over there to buy the illegal fireworks and to catch the ferry. Maybe Mercer?
I know its not a tractor but I have had extremely good luck stomping blackberries with the bulldozer. Set the blade 3 inches off the ground and go forward. The pile is pretty small at the and after being compressed. This works unless the plantation is more than about 8 feet tall when the dozer just crawls under the plants. The same should work with a FEL provided you can get good enough traction.
Depending on your intended final use for the area, I say don't worry about the root system. After running an implement above the ground and cutting/tearing/piling up the bulk of the above ground stuff then you will only have the occasional spear shooting about 2 feet out of the ground and the "stumps". Mow the area with the brush hog and then disc it. Keep it under control from this point forward or it will come back. It will always come back if you let it. The birds eat the berries too and they will spread the seeds.
Salmonberry, devils club, pretty much all underbrush works the same way. The problem is when you run into a stump or find a car, house, boat, etc. within the plantation. A guy could make a lot of money on the side if he didn't mind clearing blackberries from lots.
Blackberries are nothing compared to a nice huckleberry pie. We have a dark blue huckleberry up here in WA that grows wild. It is like a blueberry but smaller and more powerful. Best of all it is an attractive evergreen plant.
Highbeam-
Yes we are on Bainbridge Island. I'm in the process of determining if I truely need a backhoe or weather a boxscraper would suffice. Other than the occasional planting of trees and disrupting of piles of hardened clay, I believe that the FEL and boxscrper could do it. That extra $6K for the backhoe and subframe really hurt!
Bonehead
2022 LIUGONG 925E EXCAVATOR (A63569)
2022 LIUGONG 925E...
2019 Chevrolet Silverado 2500HD Crew Cab Pickup Truck with Liftgate (A61573)
2019 Chevrolet...
66'' BUCKET WITH TEETH (A61567)
66'' BUCKET WITH...
CUSHMAN REFRESHER GAS GOLF CART (A63276)
CUSHMAN REFRESHER...
Bushwhacker ST120 Offset Batwing Cutter (A64047)
Bushwhacker ST120...
17601CFL (A59228)
17601CFL (A59228)
