Richard
Super Member
- Joined
- Apr 6, 2000
- Messages
- 5,036
- Location
- Knoxville, TN
- Tractor
- International 1066 Full sized JCB Loader/Backhoe and a John Deere 430 to mow with
I've got a field I cut. I use my JD 430 with mower. It went down for 2-3 weeks so I put my Woods 72" finish mower behind the JD tractor (not the 430).
What I noticed is the Woods RFM (with new blades I might add) left a LOT of clumpage, windrowing, especially in a certain area where I already know there is a difference in the grass. Maybe it's more dense, maybe it's got more weeds??
Yesterday, the 430 was back up & running so I cut the field again (and this has pretty new blades too).
The cut quality of both is "good" however, the cut quality when using the 430 is more along fantastic. Much more even cut (fewer sprigs that got bent over still get cut whereas on the Woods, they SPRING back up when I'm gone). The JD will still have some sprigs pop up but it's one here & there. The Woods simply doesn't have as refined of a cut as the 430.
That got me wondering.... since the Woods is a "finish" mower..... is it going to be expected to give as refined of a cut as a garden tractor with belly mower?
THEN.... I got to thinking.... (takes me about 1 1/2 hours to cut this field so I have plenty of time to mentally dawdle)
Anyway, then, I got to thinking of brands. If the JD mower design creates this nice of a cut, would/could/does that also translate over to the engineering of their other mowers in the 15' width variety?
No, I don't EVER expect a 15' rotary cutter to compete with a finish mower or a garden tractor with belly mower. What I'm wondering is how would a Deere 15' cutter compare to the other brands 15' cutters?
At this level, the proof is in the pudding and easy to see. (430 vs Woods) It even had me wondering if I should simply sell the Woods.
(and no, I don't want this to be a brand pissing contest)
I'm looking down the road for when I replace my current 15' cutter, trying to get educated about them before it matters so I have no rush when it does matter.
Do you care about the quality of a 15' cutters cut, enough to compare brands, or do you want it to be heavy duty enough to not break and the cut is 'good enough' irrespective of how another cutter might do? (I fall into the if I'm going to cut the field then I'd like to leave it as nice looking as I can BUT, I don't lose sleep over how it ends up)
