4570Man
Super Star Member
- Joined
- Apr 7, 2015
- Messages
- 19,031
- Location
- Crossville, TN
- Tractor
- Kubota M59, Kubota L3800, Grasshopper 428D, Topkick dump truck, 3500 dump truck, 10 ton trailer, more lighter trailers.
View attachment 490556 sometimes zhit happens
I have two 9 amp Makitas I bought approximately 22 years ago. They've both been trouble free. Cost per year less than $5 each.
Terry
Gee Big Barn! How can you possibly get by with ONLY 8 COWs? Your shop looks like a COW supply house![]()
Not to worry it will do fine with cut off wheels. I do keep an extra grinder around as I kill them fairly often. Also don't like changing wheels all the time. Sanding disks, wire brushes of all types & so on.
I won't waste my money on the Drill Master stuff because it ain't worth the cheap price!!
How ever, I just installed Hardie Plank Siding on a 2568 sq ft house this past summer and used the Chicago Electric grinder with a diamond blade to cut and trim all the planks and it is still working great!
The Hardie dust is deadly because it is so fine and you can't breath it. I blew out the dust from the grinder from time to time with compressed air.
I own half dozen others and they are still working great.
Keep in mind that Harbor Freight has two lines of power equipment, "Drillmaster" and "Chicago Electric". If you buy the cheaper Drillmaster stuff, it's a shot in the dark. Sometimes it will hold up and sometimes it will be trash in a month. The Chicago Electric stuff is generally much better built. Both go on sale from time to time.
I bought a diamond cutoff wheel because I was afraid of that happening. Although I'd guess it's a fake picture. View attachment 490558
Knowing I would need it someday I bought a Harbor Freight 4 1/2" angle grinder when it was at a good price. Also got a 10 pack of metal cutoff wheels.
Today was the day so I pull everything out and start by reading the grinder's instructions. First thing it says is: "not for use with cut-off wheels".
Are their bearings too cheap to stand the side stress, or is this a safety issue?
(It cut-off my eight bolts just fine, thank you...)
Some of mine are the same way, I use a left over cutoff wheel as a spacer to raise the new disc up just enough to be able to tighten it up.Do the cut-off wheels install ok? I know my grinder takes depressed center grinding wheels, and it has a metal back-up piece with a hollowed out area for the depression in the wheel. When I use cut-off wheels I have to put washers on it to support the cut-off wheel, I do not have the proper back-up piece for the flat cut-off wheels.
Have you ever taken one of the HF grinders apart? I take everyone that I buy apart, clean out the "WAX" that they call grease and replace with a good load of moly grease. The factory wax is so thick and not enough to reach the gears that it does not lube the gears at all which is why they wear out. I use mine quite a bit and most of them are over 5 years old and still no problems. We were using one with a power brush and it got so hot that you couldn't hold it even with a welding glove on and it is still working fine. Any electric motor will overheat if stalled down and the HF motors are not that powerful to start with especially the ones that used to go on sale for $9.99 from time to time. I like the more expensive one with the paddle handle and the larger amp motor.I had one that ate the gears in the rotating head.. I took it apart and found the teeth gone.
I was cleaning the rust and paint off an old machine w/ a wire wheel and was going at it for 2 days straight w/ a lot of side thrust.
Makes for a lot of noise when the gear goes..
but I had used it religiously w/ a cut off wheel before then.
I THINK the problem lays in the gearing, from where it goes from straight to angle.. cheap as ****..
