Cut-Off Tool
/ Cut-Off Tool #21
Maybe I mis-read, but I dont think he was talking about HF. I think he was talking about a ridgid outlasting them all??
My comment was noting that neither the Bosch or HF survived. If you can break a Bosch tool, I would check out the operator rather than rag on the brands.
/ Cut-Off Tool #22
Im about 40 miles from HF, 35 from HD, 25 Lowes and Menards. The closest thing is a Big R that is about 20 miles away. Any tool breaking late on a Saturday or Sunday is a project-killer. I have had Harbor freight power tools in the past. Not only do they not last, they also don't perform well usually. On top of that, they "feel" cheap.
/ Cut-Off Tool #23
HF tools are cheap and no pro should own them. However, when you can literally buy ten HF grinders for the price of a Makita or Bosch or Fein, it is hard to argue that HF tools are worthless. Buy two spares and pocket the change.
/ Cut-Off Tool #24
I have one Dewalt 4.5" grinder and 4 HF of various cost (10-20 bucks each) Some of them are 5 years old and still run perfect. The Dewalt is a few years older but the brushes are failing in it and sometimes it stops running. They all get used about the same amount with the wire brush being the heaviest power drain on any grinder. I too remove the angle gear head and put in some good grease to replace the bees wax that they come with. Every time I open one up, there is a small glob of hard wax in the head but nothing is on the gears so it is imperative that the heads get grease if you want them to last.
While I don't use them 8-10 hours per day, I do use them just about every day for a few minutes. I keep them loaded with flat wire brush, cup brush, cut off wheel, grinder wheel and tiger paw (sandpaper disc) so what ever I need, I just have to plug it in and go.
/ Cut-Off Tool #25
I forgot to mention that other than the Dewalt which I think I likely found on sale for $50 or so, I have less than 70 bucks invested in all the other grinders and no way would I spend $400+ dollars to get 4 more Dewalt at todays prices.
THe HF grinders are not as powerful as the high priced ones, but I find them plenty strong enough for average duty. The 7" HF side grinder I bought will turn a 9" blade with plenty of power and not stall at all. The 4.5" grinders will get hot if you labor them for a long time and hard with a power brush. So far, none have burned up on me.
So would I prefer to have one $150 that I had to constantly switch attachments on or 7 of the $20 HF for less money. I think the answer for me is pretty clear.
/ Cut-Off Tool #26
Unless you work for NASA, any tool purchase has to consider bang for the buck. I doubt anyone would argue HF tools excel in comparison to the true pro brands made in Japan or Germany but HF tools can still offer tremendous bang for the buck.
/ Cut-Off Tool #30
/ Cut-Off Tool
Thanks guy.
I just got back from the steel supply, I got two 24' 1x1 11gauge square. I was cutting with the 14" DeWalt chop saw, I made the first cut fast like always and for the second cut it didn't trow as many sparks like always just a few :(
Anyone know what is wrong with it?
/ Cut-Off Tool #32
The ridgid completed the job, and has kept going since. Lifetime warranty which hasn't been needed.
https://www.ridgid.com/us/en/half-inch-two-speed-hammer-drill
The bosch was bought new when I was a kid (mid 80's). It had a pretty easy life, but ended up melting the wiring to the armature. It didn't mechanically fail per se, it did melt though.
Bosch 1/2 in. Hammer Drill-1191VSRK at The Home Depot
1/2" holes in 4500psi concrete cooked a bunch of drills. The ridgid came out fine.
I've got 2 of their 1/2 cordless hammer drills now too. Once was bought stand-alone, the other came with a kit. Lifetime warranties on everything - even the batteries. I'm done buying dewalt.
/ Cut-Off Tool #33
..... I made the first cut fast like always and for the second cut it didn't trow as many sparks like always just a few :(
IMO, two things. ;)
First, your wheel has probably loaded up with metal and needs the abrasive edge 'opened up'. 'Tool houses', 'Bolts-R-Us', 'paypalbay' etc have 'dressing sticks' for vitreous wheels (bench grinder, etc). A few gentle dabs on the edge under power should do the trick. Wear curved lenses or w/side shields and watch the dust.
Angles and square tubes don't cut well with sides flat to a wheel or sawblade. :thumbdown: Ideally, either works best when oriented as with the guard linked above. Cutting across wide, and then narrow, then wide again requires adjusting downfeed pressure awkwardly as wheel contact goes thru' extremes. The wheel runs hot under the wide stuff and metal fuses to the edges under all that heat. (less 'chip clearance' there too ...)
You want to have as much the same cross-section going thru the cut as is possible, saw OR cut-off wheel. Angles are easy to clamp down with the corner up. With square tubes its nice to have a pair of v-blocks to hold stock at 45^ and you still want to clamp the work securely somehow. btw: In a pinch one can scab up v-blocks from wood if they will remember to wet 'em down a bit before makin' sparks. tog :)
/ Cut-Off Tool #34
DXN1EL said:
Thanks guy.
Glazed the edge of the blade. Try cutting a piece of thin stock (1/8"X1") on edge.
Caterpillar Service Letters from the 1990's (A63117)
Caterpillar...
2015 International ProStar T/A Wet Kit Day Cab Truck Tractor (A61573)
2015 International...
UNUSED WOLVERINE 6' SLIP ON FORK EXTENSIONS (A64281)
UNUSED WOLVERINE...
2005 Manac 48' x 102" Aluminum Fixed Spread Axle Trailer (A62613)
2005 Manac 48' x...
2 new 10'' Pallet fork extensions (A61567)
2 new 10'' Pallet...
2020 MACK ANTHEM 6X4 T/A SLEEPER TRUCK TRACTOR (A59912)
2020 MACK ANTHEM...
