Cut-Off Tool
/ Cut-Off Tool #1
DXN1EL
Texas
Is there any electric one, meaning other than the Harbor Freight?
/ Cut-Off Tool #2
Oh yeah, Milwaukee, DeWalt, Makita to name a few.
/ Cut-Off Tool #3
Yep, just a straight grinder in that video fitted with a cut-off disk. Most popular now days is the angle grinder.
I have 4 10A dewalt's I use often. Each has it's own purpose: wire cup brush, flap disk (sand paper), grinding disk, and cut-off disk.
Then I have a Ridgid battery powered one (just got it recently), and a big 15A dewalt monster.
/ Cut-Off Tool #4
I guess there's probably not any less costly one than the one in the video with half a decent reputation. I've seen some cheapo flea market specials that would last until you plugged it in. Any particular reason you are looking at one versus a cut off wheel on a grinder?
/ Cut-Off Tool #5
Finding a HF electric tool which isn't a single use item is the exception, not the rule. Of the tools I've tried, the only one I still have is their porta-bandsaw. I've destroyed the gear boxes in their angle grinders in less than a weekend.
Buying them because they're cheap is false economy. When you make the second trip to the store (refund or exchange), you're already losing more than what a reputable brand unit with a reasonable expectation of durability would've cost up front.
/ Cut-Off Tool #6
What is that, an electric die grinder?
For my money if I were buying one it'd be more than a single purpose tool, it'd accept any 1/4 inch shanked product I chose to use.
/ Cut-Off Tool #7
Jim,
I don't think you are correct on that. I've bought many HF tools that were and still are going strong, including a 30 year old drill press. I've had a couple of duds, but nothing that wasn't made right and nothing that had a repeat issue. Never had a grinder fail prematurely when used correctly...of course I never bought the lowest 'drill master' either. Maybe they don't last as long. But a few years ago, I was at my local machine shop and piled outside the door was a bunch of burned up grinders waiting for pickup for repair. Included was HF, DeWalt, Makita, Metabo, and Milwaukee. I asked the owner which one he had a problem with most. He said "They all burn up...my money is better spent on the cheaper ones".
The above mentioned item is 20.00. A similar item on sale from a name brand is 150.00 or more. If you live any reasonable distance from a HF store, then your math doesn't add up...even if you had to repurchase the item out of warranty...two or three or even four times.
/ Cut-Off Tool #8
I should've specified that their portable electric tools are the problematic ones. I know of many of their drill presses (junk for other reasons), bandsaws, and lathes which haven't had mechanical problems.
I bill more per hour than you if my math is wrong in your opinion. The second trip to the store (which is 7 miles away) puts that tool at $60 over what I paid for it in time I'm not able to charge a customer. I'll gladly spend the extra $10 to not have the inconvenience of having to make that second trip.
I'm only spending $90 on the 10A dewalts, and I've had those for 8 years now.
Search Results for grinder at The Home Depot
It's a matter of perspective. My dad raised me to invest in quality tools to ensure I wasn't distracted by the problems which come from using substandard ones. A craftsman wrench has the same lifetime warranty as the snap-on which costs 2x more - I can't tell you how many craftsman's I've had replaced under that warranty (too many to recall), but I can tell you how many snap-on's - zero. ;) I buy snap-on's now. I don't have time for the crap that needs replacing, even if it's free.
/ Cut-Off Tool #9
Or maybe it's just me?
Electric pipe threader = up in smoke: one job
Hammer drill = up in smoke: 3 1/2" holes
Angle grinder = gear box self destructed: one weekend
1/2" belt sander (hand held) = couldn't keep belts from ripping: one day
/ Cut-Off Tool #10
I don't know,
I think it depends on just how much one has to rely on any one single tool and how often that tool is needed.
/ Cut-Off Tool #11
Understand that these cutoff tools don't have the 2:1 reduction of the similarly powered angle grinders and run 1:1 at armature speed, so be sure cutoff wheels are rated for 20k RPM or more.
If one puts a pricey new part into a high end power tool the rest of it will still show its age (cord, switch, brushes, gears, housing ..). As Grandpa said, "Nothing lasts forever, including balloons and a good time."
Question might have been, "Will 7 HFTs last as long as a $150 one?". (HFTs are $40/pair if one is that curious. :D )
Some of us are hard on tools as if nothing should ever break or wear out, or just d__ unlucky. (not me ;) ) Some are always in a big hurry, and I know guys that can trash any tool in one use if they don't know its practical limits, er' not that I'm inferring anything ...
/ Cut-Off Tool #13
Quick comment on the HF cut of tool. I bought one for spots where i couldnt get the grinder and also much easier for plumbing and exhaust work. However right out of the box I thought I had picked u the wrong one. (the box was labeled ... For Dargo).LOL
Anyways right off the first cut it died. I assumed it was toast until I found and learned the little red reset button. I think its set to sensitive as I often kick it out without allot of overworking it.But Im glad it has that switch.. Also its convient as I have a good supply of discs as the ait version used the same disc.
/ Cut-Off Tool #14
Unless you are in an area where you just cannot get to, I would also vote for the slicer disc on an angle grinder.
I also use HF angle grinders as well. From the cheap $10 one up to the more deluxe $20 one. They both work fine, but dont have near the power as my 12.2A metabo or 10A Milwaukee. I think one HF is 6A and the other is only 4.5A. Without knowing that, I could see how easy it is to burn up. So if metal hogging is needed, I get a bigger grinder. IF just knocking some paint off to weld, or touching up mower blades, nothing wrong with a HF unit.
Also, on the HF grinders, first thing you need to do is pop the head off and give it some more grease of better quality. They will last 10x's longer.
/ Cut-Off Tool #15
I can't speak for all of them, but all of the 4.5" grinders I've looked at have about 14:1 gears, give or take.
/ Cut-Off Tool #16
Jim,
I agree that investing in good quality tools is smart and you will have less headaches at inopportune times, but there is a real difference I think whether the tool is for a professional or for an occasional weekend warrior. If I have a big job and I know I will use the tool again many times, it is a no brainer to buy quality. If I need it for one or a very occasional job then a lower priced unit is something I consider. If I bought every tool at the highest quality, I would not have some tools and would have spent a lot of money on tools that did not return my investment.
/ Cut-Off Tool #17
My experience with HF grinders has been good. I buy them when they cost about $15 or less (under $10 last weekend) and mount a single disc or wire brush and never bother changing. Just buy more. I think I have five or six now. Haven't had any of them quit but to be fair I don't work them hard as I am a hobbyist not a pro. I wouldn't buy them if I earned my living using the tools all day. For weekend use however they make a lot of sense compared to spending five or ten times as much. The convenience of having one with a grinder, one with a cut off wheel and a couple of different style wire brushes and yet another with a flap disc all set up and ready to go is great. And all that for less than $100. If one dies I'd just buy another at the next sale.
/ Cut-Off Tool #18
My dad also told me something else of great wisdom on this subject: "When I'm at work, I'm paid to be frustrated. When I'm at home, I pay not to be frustrated."
There's value in not being hassled with junk breaking.
Maybe they've stepped up their suppliers lately? It's been 7 years since I let the smoke out of the pipe threader and hammer drill. You can infer all you want about my ham-fisted techniques, but the Ridgid 1/2" hammer drill I bought to replace the bosch that also burnt up on my slab along with the HF (and the Black and Decker that only made 5 holes too) - well, it's still going after completing the other 16 holes I needed to drill. I wish I would've spent that 109 bucks first after roasting the leads off the windings on the bosch. It actually melted the case. I soldered it once, but it got cooked again shortly after. That slab is like granite!
/ Cut-Off Tool #19
If HF stuff lasts as long as Bosch, either the Chinese have won or your technique is poor.
/ Cut-Off Tool #20
Maybe I mis-read, but I dont think he was talking about HF. I think he was talking about a ridgid outlasting them all??
