custom counterweight
/ custom counterweight #1
jonsstihl
Quebec, Canada
Here are a few pictures of my counterweight build
2x2 .250 wall tubing
I figure it will weight about 100 lbs when complete and will have a 300lbs block of concrete
It will be a multi purpose counter weight with a removable concrete block.
/ custom counterweight #2
a friend of mine who builds a lot of prototype farm equipment uses plastic water tanks, and that way the weight is easily removable and or fillable.
looks like a good build
Thanks. The water tank idea is a good one but I didn't want to worry about it freezing in the winter.
sorry for the sparse details, I didn't have much time last night to post between putting the kids to bed.
Like I said this will be a multipurpose counterweight with hooks to carry chains in the woods and one hook on the back to skid out logs. It will also have a vise in case I need to sharpen the chain saw. And I will put pins on it to hold the two ball mounts I use, one with a ball and one with no ball mounted for my wood hauling trailer.
I will also put a bracket on the back top post so I can put smaller branches into it and they will be held off the ground for cutting. I cut anything over 1.5" dia into firewood lengths. this idea came from those comercially available log holder stands.
I
/ custom counterweight #5
Nice job and maybe add a chainsaw scabbard or two. Could you paint mine blue? :thumbsup:
I need to learn to weld......
the chainsaw rides in the bucket with the tool box, gas can, oil jug and peavey.
so far I figure about 120$ in steel and about 15 - 20 hours but I'm no pro I take my time and I haven't been able to work a full day on it yet, just a few hours at a time here and there.
I could have probably been able to use 3/16 wall tubing to save on costs but hey, Its a counterweight it needs to be heavy and I'm not really worried about bending it.
/ custom counterweight #7
Any updates on this ballast/work box? Would love to see what a finished product looks like.
I made a few mistakes on the first build. The center post on the back section blocks the view of the hitch ball to line up the trailer when hooking it up so I have cut it out and need to add two posts that are spread out. It has legs now but the receiver is a little to high off the ground now with the legs so I have to add a new receiver down lower.
I'm still quite far away from paint and a finished project. I like to use my projects a little before painting then so that mistakes are easier to correct. I will try and post some pictures of my progress.
/ custom counterweight #9
That is one REALLY NICE unit. I like the idea that weight can be added/removed and that bare it could be used to carry stuff. Those first two pics almost look like you used stainless steel. Very nice job. Wish we lived closer - you could build me one!!
/ custom counterweight #10
Nice work. If you can make it. Do it. The self pride well worth the time.:drink:
2015 CHEVROLET SILVERADO 1500 (INOPERABLE) (A67714)
2015 CHEVROLET...
2015 CTS (A67714)
2015 CTS (A67714)
2007 INTERNATIONAL MAO25 SERVICE TRUCK (A66091)
2007 INTERNATIONAL...
2009 ALLMAND MAXI-HEAT MH1000 HEATER (A68842)
2009 ALLMAND...
BOAT MOTOR (A66738)
BOAT MOTOR (A66738)
2020 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A66736)
2020 Chevrolet...
