current project
   / current project #11
Too cool, I've been thinking of some kind of screen system like this.
Although mine would be stationary with some type of hopper to dump into.
Would love to see some closer shots of the front end, particularly the drive system for the screen drum.
   / current project #12
Wow, that auger/conveyer belt setup is downright brilliant. I can't even begin to imagine the math that went into the gearing setup! A smaller scale version of somthing like this would be invaluable to me. As a horse owner myself, I curse all large rocks I come across in our arena and round pen.
Just one question comes to mind...
How many PTO HP does that little deere of yours put out, does it run the whole works without any trouble?
(runs off to his drawing boad with some new ideas...)
thanks for sharing...
   / current project
not much power, it can be turned by hand
the math was that looks good and vary engine speed
if i was to start again id do some things differently but i had to make do with what i had so in some respects its a kludge
i may upgrade it in the future
   / current project #14
I would think stationery would be more troublesome than movable, due mainly to having to handle the material three times. Once to load it, once to haul off the clean dirt and once again to haul off the rocks. Plus allowing room to manuever around it, high enough to get under it, etc.
I ran stranding machines for years that were just big tubes, made of 1.5" thick steel by 100 foot long. Most were run by belt drive with rollers underneath for them to spin on. I often wondered why they didn't design them to just power the rollers since the weight of the tube wasn't going to allow it to slip. Must have been a reason, but it always slipped past me.
What I want to know is where did you get that tube? Seen some things similar but never exactly like it, and it looks just like it was designed for that purpose.
I wonder how much trouble you will have keeping the small rocks cleared out of the holes in the tube. Since they are inside trying to get out, a pressure washer might be the way to force them back in and continue to the rear. A daily maintence of a few minutes with a pressure washer might be all that is needed to keep those rocks from filling all the holes.
Chickenman,
The design ideas that you would consider on your next one is what everyone here is interested in hearing. Things that you learned by building this one would save the next guy from having to do the same learning curve. Kind of hard to admit one's mistakes, but in reality, they are the same thing each and everyone of us have done. There is always a better way and you have the most experience at it so far, so that makes you the expert!
David from jax
   / current project #15
Can you post a bigger photo of the pick up tube ... where & how the dirt is collected?
I can't tell for sure, but it looks like you have an auger screw to do this?
Thanks
   / current project #16
I would be interested in seeing more closeup pictures as well. I'd like to see what makes the machine work. As a kid, I spent a lot of time picking up those big rocks from the arena.
   / current project
the screen is mad of 2 pieces of 24" steel pipe and expanded metel rolled to a diameter of 24' with 2 strips of 1/4x6 steel rolled to splice it all together ill post a pic later
no problem really with stones clogging the screen
i made some mods yesterday and today it works better but i still need to add something to make it more efficient
ill post more pics when i get a chance
   / current project #18
Very nice way of recycling an old potato digger !
A local landscape contractor has a BIIIGG rotary screen just like that, only its fed by a wheel loader.
Instead of using a pressure washer to clear small gravel from the holes in the drum as someone suggested here, this machine is using a rotary broom to push the gravel and vegetation out of the holes by the nylon threads. SM 720 PROFI
   / current project #20
Yeah, I am a little rusty on my German, also.
David from jax
Cushman Electric Cart (A55851)
Cushman Electric...
2014 FREIGHTLINER CASCADIA (A58214)
2014 FREIGHTLINER...
Payment Instructions (A55272)
Payment...
2003 TRAVIS BODY & TRAILER ALUMINUM BELLY DUMP (A58214)
2003 TRAVIS BODY &...
2016 Kubota SVL75-2 (A53317)
2016 Kubota...
Toro Zero Turn Lawn Mower (A56859)
Toro Zero Turn...
