Cub GT 1554 issues
/ Cub GT 1554 issues #1
das fisch
york, maine
kubota b7200 hst
I have a gt 1554 with the kohler courage 27. It has always been hard starting and requires a boost to get the starter to turn adequately. The starter finally died, new one is on the way. But now after the winter I could not get it to crank at all without jumping right to the starter. Going to replace the starter solenoid at the same time, but I have a feeling it is a safety switch cutting spark. I made sure oil was topped off, so it's not the low oil switch.
Is there a way to disconnect all safety switches and run the engine bare bones to test and then work backwards from there?
/ Cub GT 1554 issues #2
The two safety switches that would prevent starting are the clutch/brake switch, which can be fun to get to on some, and the pto switch. Oil pressure switch will allow start, but then would either turn on a light or kill the engine. the seat switch doesn't effect starting just running after the start.
/ Cub GT 1554 issues #3
I was able to download a service manual with a schematic from the Cub Cadet factory website.
/ Cub GT 1554 issues #4
Could you post the website address. I have been looking for a service manual for the RZT17.
Richard
2017 FORD F-350 XL 35' NON-INSULATED BUCKET TRK (A63276)
2017 FORD F-350 XL...
2014 Buick Encore SUV (A61574)
2014 Buick Encore...
Dual Tailwheel Rhino 284 7ft Cutter 2.5in cut capacity (A63689)
Dual Tailwheel...
2016 Ram ProMaster 2500 Cargo Van (A61573)
2016 Ram ProMaster...
Like New! Kubota L2501 HST Tractor Package – LA525 Loader, RCR1260 Cutter
Like New! Kubota...
1986 Ford LN8000 Fertilizer Truck, CAT 3406 Engine, Ag-Ready Workhorse (A63689)
1986 Ford LN8000...
