Cub GT 1554 issues
/ Cub GT 1554 issues #1
das fisch
york, maine
kubota b7200 hst
I have a gt 1554 with the kohler courage 27. It has always been hard starting and requires a boost to get the starter to turn adequately. The starter finally died, new one is on the way. But now after the winter I could not get it to crank at all without jumping right to the starter. Going to replace the starter solenoid at the same time, but I have a feeling it is a safety switch cutting spark. I made sure oil was topped off, so it's not the low oil switch.
Is there a way to disconnect all safety switches and run the engine bare bones to test and then work backwards from there?
/ Cub GT 1554 issues #2
The two safety switches that would prevent starting are the clutch/brake switch, which can be fun to get to on some, and the pto switch. Oil pressure switch will allow start, but then would either turn on a light or kill the engine. the seat switch doesn't effect starting just running after the start.
/ Cub GT 1554 issues #3
I was able to download a service manual with a schematic from the Cub Cadet factory website.
/ Cub GT 1554 issues #4
Could you post the website address. I have been looking for a service manual for the RZT17.
Richard
2006 Ford F-250 4x4 Crew Cab Pickup Truck (A61573)
2006 Ford F-250...
2024 Bobcat T86 (A60462)
2024 Bobcat T86...
2021 Takeuchi TL10V2-2 Track Loader with 76in Tooth Bucket (A63689)
2021 Takeuchi...
RAIN FLOW 1 PANEL SLEAD BEDDER BED PRESS (A63291)
RAIN FLOW 1 PANEL...
2016 Dodge Charger Sedan (A61574)
2016 Dodge Charger...
CASE INTERNATIONAL 21' FIELD CULTIVATOR (A63291)
CASE INTERNATIONAL...
