Mowing Cub Cadet, no more reverse mowing.
   / Cub Cadet, no more reverse mowing. #11
Where's that metal tab located and how do you move it?
   / Cub Cadet, no more reverse mowing. #12
The Deeres have a reverse over ride feature like the Kubotas. At least my SSt18 and a neighbor GT235. I think it is a 235 /forums/images/graemlins/confused.gif
   / Cub Cadet, no more reverse mowing. #13
I just simply unplugged my switch and tapped over the connector so the elements wouldn't get in it.
Its great to mow in reverse again.
   / Cub Cadet, no more reverse mowing. #14
JayC,
You didn't say what machine you have, but maybe most are the same.
Follow the reverse pedal rod through frame of tractor.
My switch was located above the rod on inside of frame.
You can look under the inside of the frame with a small hand mirror if your deck is attached.
The metal tab to push on the switch is very thin, can easily be bent to one side to miss the switch.
This way nothing has to be disconnected and is easily bent back in case you have to have warranty work done.
Hope this helps.
   / Cub Cadet, no more reverse mowing. #15
Thanks. I will have to look at it some time and see where I get. If I recall, I mentioned up above that it was a 2166. It's a good mower but I hate not being able to mow in reverse. Thanks, again. /forums/images/graemlins/smile.gif
   / Cub Cadet, no more reverse mowing. #16
On the Cub 2250, do I use the motor connector or the reverse pedal rod switch to bypass the PTO cutoff?
   / Cub Cadet, no more reverse mowing. #17
</font><font color="blue" class="small">( On the Cub 2250, do I use the motor connector or the reverse pedal rod switch to bypass the PTO cutoff? )</font>
Tell us a little about the 2250, like what year is it? I'm not familiar with it or when it was made. The others on this thread have current models for the most part, so its was easy to kinda show them where to look...The foot pedals are the activator so watching the reverse pedal when depressed fully must press against something underneath...Dont cut anywires because usually you dont need to....
Let us know how you make out after looking underneath -and yes the deck might need to be removed first....
Duc
   / Cub Cadet, no more reverse mowing. #18
Oops! Its a 2150.
   / Cub Cadet, no more reverse mowing. #19
How about that other safety feature, get off the seat and a switch turns off the engine. I've disabled the reverse cutout and motor shutoff on an 1860, 1862, 1872 and an older 149 I had. I did leave the safety that disengages the blades when you leave the seat intact.
How about the graphic newer PTO shafts with the poor guy wrapped around it. or the missing fingers graphic on new chippers.
Curt
   / Cub Cadet, no more reverse mowing. #20
i believe he has the lt1022 which is what i had before i traded it for an ih cub cadet 682. instead of messing with the foot pedal area, the wire is connected directly below the seat under the frame. very easy to disconnect and reconnect. they made it easy to disconnect because they know everybody hates it.
2021 MULTIQUIP 25 WHISPERWATT AC GENERATOR (A59823)
2021 MULTIQUIP 25...
78" ROCK BUCKET (A52706)
78" ROCK BUCKET...
Deere 331G (A53317)
Deere 331G (A53317)
2025 CFG Industrial QK18R Mini Excavator (A59228)
2025 CFG...
2002 Ford F-550 Crew Cab Landscape Dump Truck (A56858)
2002 Ford F-550...
2005 MACK CV713 TRI AXLE 16FT DUMP TRUCK (A59575)
2005 MACK CV713...
