Cub cadet gt 2544 with kohler command ch 670 after 15 to 30 minutes sputters like it’s getting no fuel then dies.
   / Cub cadet gt 2544 with kohler command ch 670 after 15 to 30 minutes sputters like it’s getting no fuel then dies.
What causes a lawn tractor to sputter and die
   / Cub cadet gt 2544 with kohler command ch 670 after 15 to 30 minutes sputters like it’s getting no fuel then dies. #32
Lack of fuel, air, or spark.
What would cause an lawn tractor to sputter and die if it has good spark and air
And the fuel pump is working with fresh gas
   / Cub cadet gt 2544 with kohler command ch 670 after 15 to 30 minutes sputters like it’s getting no fuel then dies. #35
Fuel cap not allowing air in, eg vacuum locked.
Carb float 'water logged' if cork type or if metal- a hole in it.
Could also be a wire grounding out on ignition low voltage side.
   / Cub cadet gt 2544 with kohler command ch 670 after 15 to 30 minutes sputters like it’s getting no fuel then dies. #36
Build up with in carburetor mix carburetor with gas.
   / Cub cadet gt 2544 with kohler command ch 670 after 15 to 30 minutes sputters like it’s getting no fuel then dies. #37
Fuel shut off solenoid on carburetor. Check if it has one.
   / Cub cadet gt 2544 with kohler command ch 670 after 15 to 30 minutes sputters like it’s getting no fuel then dies. #38
Must be a trick question...
   / Cub cadet gt 2544 with kohler command ch 670 after 15 to 30 minutes sputters like it’s getting no fuel then dies. #39
If it idles but won’t accelerate, unscrew the main jet and run a thin brass wire, aluminum wire or a bristle from a brush through the jet to clear any gunk. If worried about damaging the jet during removal just leave it in and carefully clear it.
   / Cub cadet gt 2544 with kohler command ch 670 after 15 to 30 minutes sputters like it’s getting no fuel then dies. #40
Assume this is your Cub 2544 with the Kohler 21 twin Cylinder HP Command Engine you are asking about?
All the replies above are "spot on" as it seems to be a fuel issue. My experience and suggestion after rebuilding the CC 18HP Magnum carb, replacing fuel pump, is to get a complete replacement carb setup.
My CC 1811 Kohler magnum became a hard starting engine - rebuilt the carb, installed a new fuel pump still hard to start. Replaced the carb 3 years ago - now it kicks off immediately. very little choke required anymore. IMO with the methanol gas, the seals swell and jets become clogged, so a rebuild kit only solves part of the problem.
To test, remove the air filter housing, put some gas in a spray bottle and spritz the carb, start it, then "spritz" as needed to keep the engine running.
If this works, then either order a new carb or do a carb rebuild.
2019 Allmand Night-Lite V-Series 7kW S/A Towable Light Tower (A55973)
2019 Allmand...
Killbros 260 Seed Conveyor (A56435)
Killbros 260 Seed...
ECHO TIMBER WOLF CS-590 GAS CHAINSAW (A57192)
ECHO TIMBER WOLF...
2014 Ford F150 (A55973)
2014 Ford F150...
2006 INTERNATIONAL 7400 6X4 DUMP TRUCK (A52706)
2006 INTERNATIONAL...
2016 Ford Explorer AWD SUV (A55853)
2016 Ford Explorer...
