Cub Cadet EX Series
   / Cub Cadet EX Series #1
callaway2u
Looking for any information on the Cub Cadet EX 2900 or the EX 3200
Compact tractors. Prices, realiablity. Any issues with them, etc
   / Cub Cadet EX Series #3
There is a specific Cub Cadet forum here on TBN. You may get more replies and answers by posting your question in that forum. Good Luck. BTW, welcome aboard. :tractor:
   / Cub Cadet EX Series #4
Welcome aboard! Good luck with your questions.
   / Cub Cadet EX Series #5
WELCOME to TBN :)
I moved your thread to the Cub Cadet Yanmar & CUTs Forum.
   / Cub Cadet EX Series #6
We've had an ex2900 for a couple months. It's a 2011 and we got it with 13 hours on it for 12,200. It has a front end loader with loaded tires and the brush guard. It's had ample power for snowplowing this year, although we haven't had a ton of snow. I have no reservations about the power. We will also use it for mowing grass. we love it. only complaints....no cup holder, you have to remove the side panel to check oil, and it's a little tight mounting and dismounting. I've had tractor gurus look at it, and they say it's built very very well.
   / Cub Cadet EX Series #7
I just bought EX3200 with front end loader and turf tires for $14,600. Be interested to hear how that compares with prices you are seeing. So far I have moved some large logs and some dirt and I love it.
   / Cub Cadet EX Series #8
I've owned my EX3200 for 2 years. It has been a good tractor for moving snow and dirt with the loader and a box blade, I also use it on a 5' rotory mower and 52" tiller with no problems. Downside: When I turn around to watch attached equipment my knee hits the key and turns the unit off if I'm not careful,(with the seat all the way back). When using the loader the rearend is light, and had to design weight to counter that. The same for the front when I use the 5' mower on three point, again I designed weights for this. I've been unable to find wheel weights made for this tractor which would be nice.
   / Cub Cadet EX Series #9
are your rears loaded?
   / Cub Cadet EX Series #10
I have a 2008 EX3200. It's been very reliable, no service issues, easy start etc. As already mentioned, operator station a little tight. I use mine with 6' box blade, 5' rotary mower, 6, landscape rake, and a middle buster. A little light in front with the mower on and loader off, especially if grass is damp but 4wd compensates well.
3010 - any pics of the weights you designed for front? I haven't been able to find anything to work with the FEL mount.
2017 Ford F-150 Crew Cab Pickup Truck (A54814)
2017 Ford F-150...
CAT 938G Wheel Loader (A47477)
CAT 938G Wheel...
2012 Freightliner M2 106 Asphalt Pothole Patcher Truck (A55852)
2012 Freightliner...
Plasmarc PM150 Plasma Cutter (A54811)
Plasmarc PM150...
UNUSED 70PCS White Metal Roof Panels (A53117)
UNUSED 70PCS White...
