Cub Cadet 737-3062 Fluid Hydr/Trans G
   / Cub Cadet 737-3062 Fluid Hydr/Trans G #1
GTSRider
Cub Cadet 3000
Must Cub Cadet 737-3062 Fluid Hydr/Trans G, be used in my Cub Cadet 3206,
or can I use Tractor supply Hydraulic Fluid ?
Also what is the capacity with new filter, on a fluid drain change ?
Thanks,
Pete
Hudson Valley , NY
   / Cub Cadet 737-3062 Fluid Hydr/Trans G #2
Synthetic Drive System Fluid Plus is the recommended fluid for late model Cubs. Many people, myself included, have been using Mobil 1 10W50 synthetic oil instead. I used it for several years in my 3235 with no problems. Mne had an oil leak at the time and $40+ per gallon was getting costly.
Bob B.
Bob B.
Thanks Bob.... will consider a synthetic.... but probably won't go that route... tractor is old , with about 1,200 hrs.
on it...put a lot of new parts on.... CARB to fuel tank is all new. new seals in hydraulic lift lines also.
but anyway.....would you know capacity of fluid in rear tranny ? .....of course , I can always fill slowly ,and check level with dip stick.
   / Cub Cadet 737-3062 Fluid Hydr/Trans G #4
The 3206 manual calls for a capacity of 4.5 quarts.
Bob B.
Giyi 46" Mulcher (A53316)
Giyi 46" Mulcher...
2025 JMR 40in Single Cylinder Grapple Skid Steer Attachment (A55787)
2025 JMR 40in...
2017 John Deere Gator TS Utility Cart (A50324)
2017 John Deere...
2012 Dodge Ram 1500 Tradesman Crew Cab Pickup Truck (A55788)
2012 Dodge Ram...
Miva Mini Excavator Attachment Set (A53316)
Miva Mini...
4448 (A47477)
4448 (A47477)
